Damn head gasket, I hope
Ok I finally got around to putting the motor back together on my turbo d16y8. It has been completely rebuilt from the ground up. My most recent addition is the new Bisimoto turbo cam as well as his racing valve springs. So I put the head on yesterday and tourqued it down finished everything else and went to start it. Started and sounded great but then i see a moster oil directly below the cam gearwhere the head meets the block. So heres the question, the other day i started to tourque down the head then had to stop then did it a later time trying to use the same head gasket. Do u think that caused the oil issue? I do but i wanted to check. Also any specific gasket type or thickness I will be running upwards of 18 psi. Thanks in advance
that's odd, but i agree with these guys about not torqueing all of the bolts/studs down, you should at least finish the sequence for whatever torque step you are on. are you using arp studs?
and you are positive that it is not the cam seal? or valve cover gasket? both could let the oil run down in that general area
And heres mine my sign. Forgot to put the damn camshaft seal on the side of the cyclinder head. Thank you for all the help I just over looked something little and got in a rush.
btech
Aug 19, 2006 01:15 PM
