post your cheep slick and skinny setup
most people on here with skinnys are ballers and have either Welds, Bogarts, Lenzo etc...
thats an area where you shouldnt cheap out on...
i run drag dr23 15in in the front and lenzo in the rear with M&H tires....flat black.
Stickied at the top of this forum is a topic:
Forum Rules and FAQ - READ BEFORE POSTING
It says:
It says:
Originally Posted by Forum Rules and FAQ - READ BEFORE POSTING
Rules
7. Bump once and if you still don't get the info you're looking for just let it die, don't bump it again. If you bump the topic a second time, the topic will be locked and you will lose points. Think about this - this means that if you use your single bump on your topic after an hour, when it's still at or near the top of the forum topic list anyway, it will be wasted when it doesn't accomplish anything for you.
