Bad IACV
ok so i'm trying to use the linear iacv on the y8 manifold, was using the 3 wire rotor iacv on the y7tb. Blocked that off and did the 2 wire pinout on the ecu. using a y8 5spd ecu. car idles fine. under load rpms bounce around 2k then fine after that. could i have a faulty IAC? if any other info is needed let me know.
uindaway
Nov 12, 2012 01:25 AM
CivicPride97
Aug 1, 2009 12:01 PM
combz
Jul 15, 2007 02:59 PM
SPOON_BeIgHtEeNsEe
Sep 25, 2003 03:03 PM
