Type R suspension Question
- bigger rotors
- larger/stiffer front calipers (same size piston though)
- 5 lug hub
- larger wheel bearing (I think)
- Stiffer/cheaper front compliance bushings
- Stiffer damper valving
- Stiffer/lower springs
- special upper shock hat bushings
- stiffer rear lower control arms (different style shocks though)
- Larger rear sway bar (22mm)
- Larger rear sub-frame to keep larger sway bar from tearing it...
- 5 lug hub
acura, differences, durability, integra, it, original, r, rl, suspension, suspensions, suspetion, type, typer, whats, worth
