My Speedometer is acting weird..
Old Sep 19, 2009 | 08:15 PM
runtohell121's Avatar
Default My Speedometer is acting weird..
I don't know what is wrong with it, but sometime it says I'm going at 0 mph when I'm going about 50 mph. Sometime when I'm going 70 mph, it says I'm going over 100 mph. Is there a fix to this? The RPM section seems correct along with the temperature, but the fuel gauge is a bit off sometime. I have a 1996 Honda Civic EX 2 door automatic.
Old Sep 19, 2009 | 08:40 PM
Default Re: My Speedometer is acting weird..
I have another question along with this question.
I bought this car as a 2nd/3rd owner, and it didn't come with a remote. I am not sure if it has keyless entry or not. Can anyone confirm that this card have keyless entry or not so that I don't have to waste money on installing an aftermarket alarm system.
Old Sep 19, 2009 | 11:09 PM
boxeocampeon's Avatar
What years the car? and it could be your speed sensor going out if not its probably a loose wire behind the gauge cluster
Old Sep 19, 2009 | 11:47 PM
worlds-slowest-EG's Avatar
sounds like loose wires to me also. grab the sensor with the key on and wiggle it while som1 watches the speedo. if it's not loose there then prlly behind cluster.
Old Sep 19, 2009 | 11:56 PM
pawl_l's Avatar
New User
speedo sensor.
worn out?
or loose connection from the guage. clean it with isopropyl alchohol.
Old Sep 20, 2009 | 03:08 AM
onsetofpurity's Avatar
throwing a code? 07 perhaps? change your VSS sensor, powerdoors? take your %&#&ing door panels off and look for powerdoor locks.
Old Sep 20, 2009 | 06:45 AM
coquieg6's Avatar
question also, i just installed an automatic cluster with rpm gauge on my manual hatch back. everything works fine but speedo doesnt start moving till im atleast at 10 mph then it jumps upt to 10mph and works fine from there. so the cluster hasnt been used in a while. will it need wd-40 or is it just a wire??
Old Sep 20, 2009 | 07:10 AM
where is the speed sensor at? I tried taking off the cluster yesterday, couldn't get that brezel off..
1996 Honda Civic EX 2 Door Coupe - Automatic Transmission
didn't have any codes.
Old Sep 21, 2009 | 03:55 PM
the clusters easy, drop the steering wheel and everything else is screws
Old Sep 21, 2009 | 10:06 PM
sensor is on top of the trans . near the back of the engine compartment. above the diff. where the halfshafts come out
Old Sep 21, 2009 | 10:16 PM
Former User's Avatar
How did you check? Did you jump the service connector or use an OBDII scan tool?
Old Sep 22, 2009 | 01:14 AM
evil_panda's Avatar
New User
check the speed sensor
Old Sep 24, 2009 | 03:36 PM
OBDII scanner
Old Oct 10, 2009 | 01:05 PM
Ok, I took a video on my speedometer.. that's how it response sometime.. most of the time doesn't work.
http://www.youtube.com/watch?v=kN8HBlLDVE4
Old Oct 10, 2009 | 02:21 PM
xwhitchx's Avatar
how i fixed mine:
un-plug speedsensor clean the conectors then get 3 little peaces of wire and strip them then put then in each on the conecting points in the plug, then plug it back in an boom it works perfect for 6-9mounth or then it gets dirty.
Old Oct 10, 2009 | 03:14 PM
Originally Posted by xwhitchx
how i fixed mine:
was your speedometer like mine though?
Old Oct 11, 2009 | 07:23 AM
Do anyone have a picture of where the speed sensor is? I can't seem to find it xD
Old Oct 11, 2009 | 01:38 PM
hmm.. ok.. my dad cleaned the VSS, still does that.. i just notice that the miles for the tank doesn't work either... it stays at 19.6 miles xD
Old Oct 11, 2009 | 02:07 PM
MHDesigns's Avatar
Check your #15 fuse under the dash.
Old Oct 11, 2009 | 02:34 PM
i'll update it when i replace the fuse.. need to go buy some fuse first
Old Oct 11, 2009 | 03:04 PM
teamjdm239's Avatar
speed sensor is above the tranny. it will be a 10mm bolt that holds it in, and there is a clip at the top of it. should be farely easy to find. you will most likely have to take your intake off to see it/pull it off.
to me it does infact look like the speed sensor, if you cant get it to operate right, just pull one off another auto civic at your local junkyard.
also, is your car vtec? one way to know for sure is that if your car is vtec, it will be a lemon in horsepower while the speed sensor is out because vtec will not work if the speed sensor is bad.
Old Oct 11, 2009 | 03:09 PM
teamjdm239's Avatar
also what i thought was pretty funny, was when i finished my eg coupe. (d15b7/mini me/on 10lbs) my motor would torque creeping into boost, and it wld shake the tranny , and the clip on the speed sensor was loose so it wld say im going 140 then drop and fluctuate depending on the amount of throttle i gave it to make the motor torque. lol
Old Oct 11, 2009 | 04:33 PM
Already checked it, it still works, but replaced with a new one.. still does the same thing, sometime the speedometer works flawlessly but sometime it doesn't.
It is a vtec what rpm does it require to make the vtec go on? 5.5k rpm? if so.. the max I'll get it to most likely will be around 4.8k rpm lol.. and my dad already found the speed sensor and somewhat cleaned it.
yea, my dad said sometime the speedometer jumped to 120mph before..
Old Oct 11, 2009 | 04:54 PM
teamjdm239's Avatar
cleaning it didnt help any?
Old Oct 11, 2009 | 05:09 PM
nope... it didn't help
