wideband gauge question.
Old Sep 19, 2009 | 06:24 PM
em1pusha99's Avatar
Default wideband gauge question.
yeah i am wiring up my AEM wide band gauge on my 94 civic hatch with gsr swap, running p72 ecu. i want to know what wire is a good wire to run off of for the 5 volt output, i was thinking the 5 volt for the MAP, but what wire color is it on the ecu? any help would be great, thank you.
Old Sep 19, 2009 | 08:32 PM
em1pusha99's Avatar
Default Re: wideband gauge question.
bump, need to know asap.
Old Sep 20, 2009 | 01:06 AM
Corksil's Avatar
buy a power inverter, put it in the dash - and use the USB charger port (take it apart and jump off that wire. Then you know it's guaranteed 5v - and you have a 120ac plug for you vibrating pocket-***...
honestly I don't know - I'd recommend using a multimeter or wiring maps in the haynes/chilton manual to find a constant 5v lead..
Old Sep 20, 2009 | 08:20 AM
Gunmetal_B20_Hatch's Avatar
You shouldnt need +5v from what I can recall... The +5v on the wideband is an output.
Old Sep 20, 2009 | 08:26 AM
Bisimoto.com's Avatar
From: Ontario, CA U.S.A. *Dyno Tuning *Performance Parts *Engine Design *Custom Parts
Check this out:
http://www.youtube.com/watch?v=Jr3-w4wdDaU
Its from an install that we did at the shop
Part II:
http://www.youtube.com/watch?v=TzhlE...eature=related
Old Sep 23, 2009 | 07:40 PM
em1pusha99's Avatar
^^^ thanks a ton! answered all my questions.
xxdevilzeroxx
Engine Management and Tuning
Jul 6, 2010 06:13 AM
leftychang
Welding / Fabrication
23
May 6, 2008 04:38 AM
danny_civic97
Mar 19, 2007 04:31 AM
vtecman253
Sep 7, 2003 10:03 AM
