I need some help with rims
Old Sep 19, 2009 | 02:11 PM
91CivSi23's Avatar
Default I need some help with rims
I currently have '91 Civic Si Hatchback. I have 17" white Moteegi MR7 rims. According to the specs, they are 17 in. x 7 in., 4 x 100mm/4.5 in. Bolt Circle, 5.5 in. I am looking at getting 16s instead but wanted to keep the same style. The 16" specs are 16 in. x 7 in., 5 x 100mm/4.5 in. Bolt Circle, 5.625 in. Is that going to be a problem?
Also, they have discontinued the white MR7s and am having trouble finding a set of 16" white MR7s. Someone mentioned that I could get the Silver ones and have the powder coated to make them white. Is that the best option?
If not, what are some options for white, 16", between 6-9 spoke rims?
Old Sep 19, 2009 | 10:59 PM
worlds-slowest-EG's Avatar
Default Re: I need some help with rims
first problem is 4x100/5x100. that is # of lugs/distance apart. 5 lug wheels won't fit 4 lug hubs.
If you can afford the powdercoat it would be great, but if not they can be painted, just make sure you prep them right.
Old Sep 27, 2009 | 04:22 PM
91CivSi23's Avatar
Ok. So I will definitely have to get the 4x100 then. How much does powdercoating cost? I'm worried that if I get them painted, the paint will start to chip. Is there a problem with that?
Old Sep 27, 2009 | 06:19 PM
racebum's Avatar
use automotive base/clear staged paint, shoot it out of a real gun and you'll get a factory new finish. don't spray paint them
RupEM1
Wheels
Jun 26, 2009 04:02 PM
ley
Mar 15, 2007 10:26 AM
semij20
Jul 7, 2006 02:34 PM
JL 74
Dec 21, 2001 02:55 PM
