1st Time on SLICKS!!
Old Sep 19, 2009 | 10:49 AM
mangina's Avatar
Default 1st Time on SLICKS!!
http://s127.photobucket.com/albums/p...t=100_1229.flv
1.79 60 ft
4.82 330 ft
7.24 1/8th @ 101.95MPH
11.1 1/4 @ 128.21MPH
can someone analyse my slip and tell me about my shifting?
I was very happy with the results.
Old Sep 19, 2009 | 10:52 AM
mangina's Avatar
Default Re: 1st Time on SLICKS!!
1.79 60ft
4.82 330ft
7.24 1/8 @ 101.95 mph
11.1 1/4 @ 128.21 mph
can someone analize my slip and suggest where to improve?
Old Sep 19, 2009 | 11:18 AM
base-op.1320's Avatar
get the 60' in the 1.6's
Old Sep 19, 2009 | 11:27 AM
mangina's Avatar
tried to lower my tire press to 7.5 psi and snapped my NAPA axle.
if I get the 60' in 1.6 would it be possible to hit a 10.9?
Old Sep 19, 2009 | 11:29 AM
locash's Avatar
Yes.. Time for some DSS axles..
Old Sep 19, 2009 | 11:39 AM
fatboy1185's Avatar
Big Cat
learn to preload correctly and you won't break axles.
Old Sep 19, 2009 | 11:43 AM
mangina's Avatar
I suck at preloading.
I guess it's time to learn.
Old Sep 19, 2009 | 12:58 PM
Yeah preload and run stock axles with no problems, get more power out the hole and maybe up you launch rpm. Def a 10 second car.
Old Sep 19, 2009 | 01:08 PM
96 GSR-T's Avatar
What is the approx weight of your Teg?
Old Sep 19, 2009 | 01:17 PM
mangina's Avatar
I used the scale @ a junk yard when it was allmotor and the scale said 2390lbs
dont know how accurate that is.
Old Sep 19, 2009 | 01:22 PM
mangina's Avatar
http://i127.photobucket.com/albums/p...s/100_1209.jpg
the slicks.
Old Sep 19, 2009 | 02:26 PM
A L I A S's Avatar
yea man preload that sucker and shes got 10's in her all day
Old Sep 19, 2009 | 05:35 PM
Are those 23" slicks with 15" rims?
Old Sep 19, 2009 | 06:12 PM
ashtons300zx's Avatar
nice time especially for your first time on slicks. You ran the same time i did but my mph was 132 in my 92 Sentra SE-R. I was running on 7 year old 24.5X7X13 m/ts that were literally bald and down to the threads on the surface. The benifit i saw from running those over my other new 22X8X15 m/ts was the longer gearing by far. I crossed in 4th instead of having to shift to 5th. Only bad part was i was getting better traction with the 22" ones because they were new and grippy.
Me and a buddy are gonna pitch in for some new 24.5X9X13 and try setting them to a bit lower psi. probably 9 psi or so.
Definitely preload. Im still running factory Nissan oem axles and have never broken one ever. Preloading is definetly key and will keep the slicks from just breaking lose due to the quick snap of the drivetrain not to mention you wont break anything.
Good luck next time out.
Old Sep 19, 2009 | 06:14 PM
dustin528's Avatar
nice man! those slicks look pretty small on those wheels...
Old Sep 19, 2009 | 06:38 PM
boosted91crx's Avatar
man must be nice to race on a level or down hill track !!! my home track is is slightly uphill and i have to trap 134+ to run low 11s high 10s
Old Sep 19, 2009 | 07:24 PM
Silva Bullit DC4's Avatar
X2! ;-)
What offset (or back spacing) are those wheels? And are those slicks 23's?
Old Sep 19, 2009 | 07:26 PM
mangina's Avatar
the slick are 23x8.5x15
Old Sep 19, 2009 | 07:28 PM
mangina's Avatar
wheels are Spin Werkes I dont know the backspacing on them but they are for GSR brakes. 15x8
Old Sep 20, 2009 | 08:40 AM
2.0_civic's Avatar
nice run.what rpm was u launching at?
Old Sep 20, 2009 | 09:05 AM
Originally Posted by mangina
the slicks.
Fixed your pic for ya. ;-)
I wanna see some engine bay shots.
Old Sep 20, 2009 | 09:11 AM
kulo's Avatar
can u preload with et street radials with stock clutch?
Old Sep 20, 2009 | 09:22 AM
GEN2 LS's Avatar
Loved
what the hell carlos! I heard you were @ benson the other week and now this? what track was this at Fayetteville? We gotta catch up bro long time no see give me a call I still live in Raleigh.
Old Sep 20, 2009 | 09:37 AM
96 GSR-T's Avatar
why couldnt you, all you are doing is holding the ebrake up and letting the clutch out, obviously a stock clutch is not a good clutch to heat up in this manner though.
Old Sep 20, 2009 | 10:45 AM
mangina's Avatar
not nice, but it works.
