GSR MANI ISSUE
Old Sep 19, 2009 | 09:53 AM
DCM's Avatar
DCM
Default GSR MANI ISSUE
Ok i have EG6 with a 95 C1 swap i bought the car already swapped .
when you get into it around 6k the car starts to backfire its *** off and it sound like its comen from the the mani .i took look at it and someone took the dual flanges out and the timing is off 4 degress would this cause it ?
brand new plugs ,brand new dizzy p28 ecu also i found out after i bought it the car was boosted at one point compression is 200 across all 4 cylinders
Old Sep 19, 2009 | 09:55 AM
DCM's Avatar
DCM
Default Re: GSR MANI ISSUE
also car runs fine up untill 6k
Old Sep 19, 2009 | 03:01 PM
DCM's Avatar
DCM
any ideas ?
blkcivic310
Appearance Build Threads
Nov 2, 2009 05:08 PM
red_honda_racer
Aug 7, 2008 08:54 PM
boostin4door
Apr 29, 2008 10:07 AM
KanzenR95GSR
May 24, 2002 11:49 AM
