Want to Buy Want to Trade/Want to Buy
WTB 94/95 vx engine wire harness
Old Sep 19, 2009 | 06:36 AM
ivicr's Avatar
Default WTB 94/95 vx engine wire harness
like he title says. i need a 94 or 95 civic vx wire harness...
Old Sep 19, 2009 | 07:53 AM
ivicr's Avatar
Default Re: WTB 94/95 vx engine wire harness
up
Old Sep 19, 2009 | 03:26 PM
ivicr's Avatar
up
Old Sep 19, 2009 | 07:11 PM
ivicr's Avatar
ttt
Old Sep 20, 2009 | 08:17 AM
Slo92EgHatch's Avatar
why 94/95 I assume any 92-95 vx harness would work no?
Old Sep 20, 2009 | 02:32 PM
ivicr's Avatar
doing some reading, it seems that 92/93 was different...unless some one kan confirm other wise ??
Old Sep 20, 2009 | 07:08 PM
JDM_DAKiD's Avatar
i have a 95 dx harness.. lmk
Old Sep 21, 2009 | 04:09 AM
ivicr's Avatar
thanx, but i need a vx harness or it wont work properly
Old Sep 21, 2009 | 09:28 AM
I'll look into it then but im pretty sure a 92-95 vx harness will work if so I have a 92 VX
Old Sep 21, 2009 | 12:23 PM
ivicr's Avatar
def, let me know. i was pretty sure they were different tho.
Old Sep 22, 2009 | 11:21 AM
what did you read that was actually different between the two? As long as its an OBD1 VX harness it should be just plug and play. Is the car originally a VX?
Old Sep 22, 2009 | 12:11 PM
ivicr's Avatar
I forget where i read the info about it...i just remember there was a blurb about the 92/93 being different. Im not sure what it was, but thats why i was also asking if any one knew for sure as well.
The car is an original VX, it was chopped and hacked by the idiot before me to make it run in "lean burn" by using the 49-state ecu and it jacked my wire harness up. So i really want to make sure im getting the right parts so that every thing works the way its supposed to.
Old Sep 22, 2009 | 10:43 PM
where are you located by chance?
Old Sep 23, 2009 | 05:50 AM
ivicr's Avatar
San Diego
Old Sep 23, 2009 | 01:26 PM
ivicr's Avatar
up
Old Sep 23, 2009 | 06:13 PM
oh so california laws then you need the special VX harness then. good luck on your search
Old Sep 23, 2009 | 06:19 PM
ivicr's Avatar
yeah. sucks to me...!
Old Sep 24, 2009 | 07:55 AM
ivicr's Avatar
up
Old Sep 24, 2009 | 04:59 PM
ivicr's Avatar
up
Old Sep 26, 2009 | 06:36 AM
ivicr's Avatar
up
Old Sep 26, 2009 | 11:30 AM
wip_customs's Avatar
i got on pm me an offer everythings there uncut!
Old Sep 26, 2009 | 02:22 PM
ivicr's Avatar
pm'd
Old Sep 26, 2009 | 02:32 PM
nihad's Avatar
Originally Posted by ivicr
pm'd
you can buy a dx harness and fab it its not hard add some wires do some searching oh how to do this.. VX harness might be harder to find..
Old Sep 26, 2009 | 04:18 PM
ivicr's Avatar
i would do the dx to vtec if i knew it was going to work. I kant find any kind of confirmation that the dx wired for vtec works for the vx motor
Old Sep 26, 2009 | 05:40 PM
nihad's Avatar
the dx harness is the same but for one thing there is no vtec no pressure signal and maybe some thing else... You will have to add the extra wires to make it work all you would have to do is run the extra stuff up to the end of the wiring clips of the dx harness and re pin it and it would then connect to the factory interior harness.. Its doable..
