OBD0 to OBD1 no start...no fuel?
Old Sep 19, 2009 | 12:49 AM
KrenzyRyan's Avatar
Default OBD0 to OBD1 no start...no fuel?
Hey guys, need help. Right now me and a couple of buds are working on a friend's 89 CRX with a B16A2. He has been running OBD0 just fine.
He bought the TD44U dizzy, the RyWire ecu jumper harness and vtec subharness. ECU is the P06 loaded with a stock b16 basemap (by Bultbynotorious here in az).
Everything hooked up right but hes not getting anything. We pulled the plugs, and hes getting spark, but we don't smell fuel.
The only code he is getting is code 22 (vtec pressure switch).
I'm thinking its the ecu...but could be wrong. What do you guys think?
searched, but couldn't find any answers
THX!
Old Sep 19, 2009 | 02:21 PM
KrenzyRyan's Avatar
Default Re: OBD0 to OBD1 no start...no fuel?
Alright, update...we went through a bunch of trials with a bunch of different ecus/harnesses, etc.
We have come to the conclusion that the rywire one isn't working. We used a jumper that Builtbynotorious had laying around, and it started right up.
So....I guess we just compare the two to get ours working right?
Old Sep 19, 2009 | 02:23 PM
twistedreality1's Avatar
if the rywire one isnt working, its probably made for a different chassis or something. contact them for a replacement
or you could do like you sugegsted, compare them, then you could modify one or the other to make it work
waspcrx19
15
Apr 9, 2011 02:28 PM
zeusdavis
14
Mar 28, 2011 08:05 AM
cwf1988
Jan 3, 2009 02:11 AM
lance_ecl
Apr 8, 2007 11:03 AM
altoid
11
Jan 21, 2005 08:49 AM
