code 43 wat to check or fix?
have a b18b1 in a 91 ef with a check throwing a code 43 not sure wat to start checking if any help il appreciated it thanks
I have this same problem. I still have not fixed it since it only happens to me when I am driving freeway speed for awhile and if I shut the car off and turn it back on the cel goes away. I do have a power loss though. Anyhow, this is what was posted on my thread. Hopes this helps.
no power loss and its running perfect ima change my gas cap it seems kinda old n stuff so wel see if any other suggestions would be great ooh and im running this b18b1 with a pr4 obd0 if that makes a difference the engine is a 98
fuel pressure and check regulator. when i got this code it was cuz vacuum line on top of regulator was not hooked up to manifold, so check that too
The EXACT same thing is happening to me; the light (code 43) only comes on if I hold a consistent speed for a while. I'm also experiencing power loss and bogging/surging at low rpms. Is it likely my o2 sensor or something else?
Never been a fan of this code. Could be a LOT of things, I've had a bad dizzy, and leaky injector render this code. If there are no noticeable side effects, check for a leaky injector.
^^ While puttin my injector wires back on i noticd that if i push down on my injector 3 & 4 fuel squirts out.. The code first popped up after i sucked up water in my intake... Could compressing the water have caused this?
^ I'm curious about this as well because I feel as though my dizzy might be at fault as opposed to my o2 sensor. I think I've read elsewhere that dizzy problems can throw code 43.
