b20b swap ecu question?
Old Sep 18, 2009 | 10:28 PM
jdmboy94's Avatar
Default b20b swap ecu question?
i have a 94 ls teg that i just did a b20b swap in and im running a pr4 ecu right now. ive read that the ls ecu runs lean on the b20? would it be ok to run the pr4 or should i get a b20b ecu? thanks
Old Sep 19, 2009 | 10:17 AM
jdmboy94's Avatar
Default Re: b20b swap ecu question?
anybody?
Old Sep 19, 2009 | 12:17 PM
BoltonGSR's Avatar
Use a P75
Old Sep 19, 2009 | 06:44 PM
hieuamn's Avatar
i have p28 chipped for ls. runs great
Old Sep 23, 2009 | 09:59 AM
jdmboy94's Avatar
ok. i just wanted to get some other opinions. idk if it would be safe to run on the pr4 or should i just get a chip for my socketed ecu?
Old Sep 23, 2009 | 10:14 AM
guy_from_nerk's Avatar
Why would a LS Ecu cause a B20 to run lean? Its a LS with a bigger bore, thats it. Same head, same rods, same crank. I used a PR4 on my B20 CRX and had 0 issues untuned.
Old Sep 29, 2009 | 08:12 PM
emperorfrazer's Avatar
I'm having the to ask the same question, glad I found this thread. I have a 90 integra LS swapped to a B20B JDM never passed emissions (ya'll know what I did LOL) But recently it started acting up not wanting to start, hunting idle, shutting off when given gas etc. So someone suggested that I put the ecu that the motor originally goes with in, but thats a CR-V ecu. Now I think I'm missing something. Any advice would be much appreciated.
Old Sep 30, 2009 | 06:30 AM
trrbl1bmx's Avatar
I used a socketed pr4 with a phearable.net basemap!! Good guys to deal with!
Old Sep 30, 2009 | 07:15 AM
worx's Avatar
i remember first time i used phearable.net i ruined my ecu tryint to do it my self. ive had no problems running ls ecus on the b20s we swap here
Old Oct 1, 2009 | 05:11 PM
jdmboy94's Avatar
ok well i have a wideband so im gonna watch it close, i just got my crank and everthing back from the machine shop, so its going togather tonite. thanks for the help
Old Oct 6, 2009 | 02:16 PM
SLURS's Avatar
i got a stock b20 too and i use the p75 and its swelll!! red lines at like 72k
rpm
Old Oct 8, 2009 | 09:10 PM
Championship's Avatar
i have a 96 b20b on my 92 gsr, im running the oem gsr ecu and it runs like dookie, anyone know if it would be ok to run any obd1 pr4 ecu?
and also, when i start up the car when its cold, it putters like hell and wont go up higher than 1.5k, i press on the gas and wants to shut off, would it be caused by the ecu or the iacv?
1kleenef
Feb 26, 2009 04:00 PM
MrMug3n
Dec 9, 2008 06:13 PM
troppop
Jul 30, 2006 04:04 AM
B18PoweredCivic
Mar 14, 2005 09:13 AM
1hotcivicSi
30
Feb 16, 2004 03:15 PM
