easy fix maybe????
Old Sep 18, 2009 | 07:22 PM
bryce warburton's Avatar
Default easy fix maybe????
i put in a new engine a f23a. engine isnt seized i believe i put the tourque converter on wrong. i pulled the tourque converter off the old engine and put on new one. from what i hear i should of put it on the tranny. then bolted to the engine then bolt the converter on. is this right cuz riight now the engine wont crank and starter kicks just wont push it battery is good i was thinking i would be able to pull the starter out and spin the crank then bolt the starter back on what do U think an easy fix or pain in the @$$
Old Sep 18, 2009 | 08:57 PM
phootbag's Avatar
Default Re: easy fix maybe????
Are you saying you installed the engine with the torque converter bolted to the flex plate? How did you get it to fit and how did you line up the input shaft of the trans with the hole in the torque converter?
Old Sep 18, 2009 | 09:15 PM
i bolted it to the the plate on the back of the engine then slid it onto the the tanny after lined up then bolted it on
John Shotton
Jan 5, 2019 07:52 PM
vincsk2003
Feb 21, 2008 07:53 AM
pkennedy
Jun 15, 2007 10:57 PM
Blaze45
Oct 18, 2002 07:45 PM
