car making noise.....
Old Sep 18, 2009 | 05:08 PM
sins's Avatar
Default car making noise.....
Ok recently when I start my car or I'm at a light I hear the car making a farting noise lol...can anyone help me out on how to fix it thanks
Old Sep 18, 2009 | 05:16 PM
SideFX's Avatar
Default Re: car making noise.....
farting noise?? wheres it coming from?
front?rear? engine bay?
Old Sep 18, 2009 | 05:38 PM
sins's Avatar
Rear...from the exhaust
Old Sep 18, 2009 | 11:12 PM
Mario245's Avatar
Bump, I have this same problem.
Old Sep 19, 2009 | 02:05 AM
grumblemarc's Avatar
The Grumpiest
Hole in the exhaust? Cheap Ebay muffler?
Old Sep 19, 2009 | 02:30 AM
Mario245's Avatar
I've noticed a hole in part of the welding before the muffler, I've seen water drop out when first starting the car after a few days of not starting it.
Old Sep 19, 2009 | 02:38 AM
anothersickhatch's Avatar
i think you are going to be a little more specific. farting noises can make a wide range of sounds.
Old Sep 19, 2009 | 03:04 AM
Mario245's Avatar
I've actually got a video of it
http://www.viddler.com/explore/Mario245/videos/1/
You can hear it more after the :15 second mark.
Old Sep 19, 2009 | 07:30 AM
Integra4lyfe069's Avatar
... its prolly just back pressure cause either ur exhaust is too big or something wrong with it
Old Sep 19, 2009 | 05:19 PM
Mario245's Avatar
I doubt it's from it being too big since I've had this car since Oct. 2008 and this just started in May.
Old Sep 19, 2009 | 08:06 PM
try listening to the engine with the hood up while its making that noise. sounds almost like a misfire. you should be able to hear it in the engine if it is.
Old Sep 19, 2009 | 08:23 PM
Mario245's Avatar
I don't hear it while listening to the engine and it only does it at idle, car drives fine.
Old Sep 19, 2009 | 09:25 PM
earlylocks's Avatar
any cels?
Old Sep 19, 2009 | 09:32 PM
Mario245's Avatar
None, used to have #41 but I went ahead and replaced the Primary O2 Sensor.
Old Sep 19, 2009 | 11:59 PM
pawl_l's Avatar
New User
check for the timing..
Old Sep 20, 2009 | 02:13 AM
I honestly don't think its the exhaust. im thinking a misfire. could be spark plugs, cap or rotor, or timing.
Old Sep 20, 2009 | 03:04 AM
Mario245's Avatar
Well I've already changed the plugs, wires, rotor and cap, and the Ignition Coil.
Old Sep 20, 2009 | 05:41 AM
sins's Avatar
Lol I thought this was my thread
Old Sep 20, 2009 | 06:10 AM
Mario245's Avatar
Whoops, got a bit carried away, sorry about that lol.
Old Sep 20, 2009 | 07:05 AM
Robert Wiles's Avatar
i have had the same problem on my old honda and its was timing i slipped a tooth take off your cover and see you can see its your timing has slipped a tooth i will be more the certin that it has just from my own expairence with the same type of problem
Old Sep 21, 2009 | 07:07 AM
sins's Avatar
dont worry about it its cool besides it can help me find out the same problem im having...
Old Sep 21, 2009 | 07:06 PM
Mario245's Avatar
Another thing: My oil smells a bit like gas but I'm not burning any oil, does that still mean my rings could be messed up?
Old Sep 21, 2009 | 10:07 PM
if you arent burning any oil, then dont worry about it.
and stop stealing threads. if you want to start a new thread, you are more than welcome.
Old Sep 21, 2009 | 10:24 PM
Mario245's Avatar
Alright because I was going to change my oil soon, just wanted to be sure.
Oil that smells like fuel would mean I have a fuel problem, correct?
Old Sep 21, 2009 | 10:28 PM
Former User's Avatar
Originally Posted by anothersickhatch
im thinking...or timing.
OP: Check the ignition timing with a timing gun.
