CA: Tein RE EK9 with Pillow Ball Upper Mount BNIB 1650
Selling a set of BRAND NEW Tein RE for a EK9, they come with pillowball upper mounts. Im located in Socal but i can ship this setup at the buyers expense. Heres all the tech information on the coils. Price is 1650.
Tein Coil-Over Damper Kit
Damper Type: RE
Part No.: DSH00-Q1LS1
Production Years : 96-00
Car Chassis Code: EM1/EJ6/7/8
Front Spring Part No.: SA140-01150
Rear Spring Part No.: SA100-01150
# Spring Rate Front lbs/in (kg/mm): 783 (14)
# Rear lbs/in (kg/mm): 559 (10)
# Ride Height Front inch (mm): -1.3 (-34)
# Rear inch (mm): -1 (-26)
# Ride Height Adjust Range Front Max/Min inch (mm) : -0.6/-1.7 (-14/-44)
# Rear Max/Min inch (mm): -0.2/-1.4 (-6/-36)
Upper Mount: P/U
EDFC Available Part : Not Compatible
Strut Kit Part :
TEIN Type RE Coilovers Features:
* Designed for drifting performance.
* Specified damping force and spring rate set up for drifting.
* 16 levels of damping force adjustment (compression and rebound together).
* Teflon coating for rust prevention.
* Newly designed spring seat and spring seat lock for easy height adjusting.
* Full-length adjustment and height adjustment for separate setting of the height and spring preload
Damper Type: RE
Upper Mount: P/U
Strut Kit Part :
mr.sedan
Suspension & Brakes
Feb 24, 2006 09:06 PM
