skunk2 pro 1s
Old Sep 18, 2009 | 03:08 PM
yfz's Avatar
yfz
Default skunk2 pro 1s
Okay so I plan on installing my skunk2 pro 1 cams, valve springs and retainers. I was going to do this while leaving the head in the car using the compressor method so it will take less work and time. Will I have to check my piston to valve and valve to valve clearances by running this cam or can I just leave my cam gears at 0? If I do have to check clearances I will just plan on pulling the head. Thanks.
Old Sep 18, 2009 | 04:05 PM
BigBlock22's Avatar
Default Re: skunk2 pro 1s
what engine is this and what pistons are being used in your setup?
Old Sep 18, 2009 | 04:07 PM
yfz's Avatar
yfz
Sorry. Its a gsr with stock long block.
Old Sep 18, 2009 | 05:09 PM
BigBlock22's Avatar
for using stock pistons it would seem safe to just throw them in. but you always should zero your cams out when installing them. especially ones with more lift and duration but i would take the head off so you can replace other necessary parts and have it inspected. if you dont get your clearances then you dont get the full advantage out of the cam since you only have so much room to play around with. you will need to pick up some special tools in order to do this safely. you might want to have a professional do this for you or someone knowledgeable help you out if this is your first time around with this particular job. if you cant get the help then do more research and gather up all the info you can. its all available here on HT if you decided to do so. good luck
Old Sep 18, 2009 | 05:21 PM
yfz's Avatar
yfz
I know how to check all clearances and I have all tools needed to do so. I was just wondering if I really needed to. Thanks for help
Old Sep 18, 2009 | 05:31 PM
slo blue's Avatar
You will be ok. just dont advance them too much
Old Sep 18, 2009 | 05:35 PM
yfz's Avatar
yfz
This is just my daily driver. I'm just looking for a little more grunt. lol.
Old Sep 18, 2009 | 05:51 PM
slo blue's Avatar
Add some p30 pistons and a good tune. it will give you a little more grunt.
Old Sep 18, 2009 | 06:26 PM
BigBlock22's Avatar
pardon me yfz, not trying to insult your intelligence. i tend to go off on a tangent from time to time. nothing personal. you might want to go to the all motor dyno thread and find all the guys using the pro1 cams and pm them regarding your question in mind.
Old Sep 18, 2009 | 08:46 PM
crx-b18c's Avatar
i ran pro1 before with ctr pistons in my itr block i left my intake cam gear at 0 and exhaust cam gear +2 that what skunk2 recomended and never had problem with them sick cams good luck
b1620vtec
19
Oct 25, 2014 02:18 AM
GSR_hatch936
Apr 13, 2010 01:14 PM
ntensemex505
Engine Management and Tuning
Sep 14, 2009 12:09 PM
RMXmitch
10
Sep 16, 2007 05:29 PM
thatwhiteguy
Apr 2, 2007 10:00 PM
