Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
rise up control on 90 legend
Old Sep 18, 2009 | 01:40 PM
Hatchd Egg's Avatar
Icon6 rise up control on 90 legend
i have a 90 acura legend and its not starting.. im thinking its the main relay for the whole car.. not the fuel pump relay? i have a hatch that once had a bad relay for the pump.. but when i go to start it, it would still crank.. well on the legend it doesnt crank.. so im thinking not the relay for pump if im correct... so i go to pull this big black piece from right under the steering coulum and it says rise up control on it.. is that the main relay for the whole car? is that piece suppose to click when you turn the car on like all the other relays? maybe that peice is what i need to get the car started? any help would be great..
Old Sep 21, 2009 | 09:06 AM
1grex's Avatar
Default Re: rise up control on 90 legend
You're looking at bad ignition switch/connections, bad starter/connections, or bad battery/connections. If it were the PGM-FI main relay, the car would crank but not start.
Old Sep 21, 2009 | 12:23 PM
Hatchd Egg's Avatar
everything is good.. but the car would not crank at all so i dont think its the main relay for the PGM-FI
Old Oct 7, 2009 | 12:19 PM
D.snogy's Avatar
Default rise up control on 90 legend
Hi
My acid pump is not available for pH control. How can I use a substrate pump to control the pH when the value rises above the set point. I dont have any problem when the pH value falls below the set point as I do have base control.
Old Feb 19, 2010 | 08:57 PM
johnjw's Avatar
delete. old thread
JDM_SOHC
19
Dec 20, 2011 04:15 PM
My_EFsedan
Sep 20, 2009 09:27 PM
stevew84
25
Jul 17, 2008 06:16 AM
MooreBoost
10
Sep 8, 2004 07:43 PM
sxecustoms
Jun 11, 2003 07:47 PM
