Suspension & Brakes Theory, alignment, spring rates....
alignment prob
Old Sep 18, 2009 | 11:52 AM
dinoz_fed's Avatar
Default alignment prob
my car is civic eg8 jdm 95.. i juz changed the whole set of subframe including steering rack, both lower arm , anti roll bar.(crossmember set) and the whole set its from dc2r. not brand new. but looks like all the bushings and the arm is in good condition. after install the set, i try to drive but the steer more to the left.. is it bcoz of i nop yet do the wheel/tyre alignment? or i have to do the tie rods adjustment? sory for my bad english...
Old Sep 18, 2009 | 12:05 PM
dester223's Avatar
Default Re: alignment prob
You need to get alignment specs then go from there. So get it on an alignment machine and get it aligned. If it does it after the alignment then you need to post up the specs that were set.
RR98ITR
Jul 28, 2016 08:33 AM
BoosterB16
Suspension & Brakes
18
Mar 17, 2011 04:29 PM
dinoz_fed
Suspension & Brakes
Sep 19, 2009 01:44 AM
XEventHorizonX
Feb 19, 2003 06:49 PM
