Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2001 honda crv turning noise
Old Sep 18, 2009 | 10:39 AM
superwell's Avatar
New User
Default 2001 honda crv turning noise
Hey guys I have a 2001 honda crv and when i am making a very sharp but very low speed turn (so full steering wheel lock to the left) and let go of the brakes, it's making a metal on metal kind of sound..which sounds like it's from the front..maybe where the axel attaches to the tranny...sort of thing. Has anyone had anything like this? I am tempted to change my dual pump fluid in the rear but I am not quite sure it's coming from the rear, so i don't want to waste my time.
Thanks in advance
Old Sep 18, 2009 | 04:13 PM
spoonfedcrx's Avatar
Default Re: 2001 honda crv turning noise
Without looking at it the first thing I woud say from your desription is change the rear diff fluid. Very common problem.
Old Sep 20, 2009 | 08:09 PM
www.megameet.org's Avatar
you should do the fluid anyway, and if thats not it and it's a gen 1 and the noise is from the front, and also over speed bumps, it could also be the sway bar endlinks.
Do the fluid, only use honda fluid, and adjust your valves every 30k if it's a gen 1
Old Sep 22, 2009 | 09:18 AM
boosted1993's Avatar
possible squealers on the brake pads..(inside pad)????
where do you live at by the way?
Old Sep 27, 2009 | 12:41 AM
gen_x_dad's Avatar
If you have yet to change your rear differential fluid, I would do that anyways as cheap insurance and eliminating a possible cause in your troubleshooting steps.
Have you inspected your brakes to ensure the brake rotors don't have rust buildup that is contacting the rotor shield? This is common during turns when the wheel bearing deflects every so slightly. Low brakes pads as was already mentioned is something else you can check at the same time.
Matt Powell
Honda CR-V & Element
Sep 18, 2019 06:30 PM
Adam Carter
Nov 23, 2016 02:26 PM
transitions
Nov 16, 2010 12:22 PM
lmccammon
Feb 16, 2005 03:52 PM
