Brake upgrade on CRX Hf
Old Sep 18, 2009 | 10:19 AM
PS122's Avatar
Default Brake upgrade on CRX Hf
I've read a zillion threads on EF brake upgrades but I have not seen my question answered...
I have a '91 CRX HF and am upgrading to 10.3" DA brakes (knuckles, calipers, discs). I'll of course be swapping in the required DX/Si axles as well. All of the posts I have found are for DX and Si both of which use an 8" brake booster while the Hf uses a smaller 7" booster. Will the smaller booster be okay with the other brake mods?
FWIW - I also plan on upgrading to a 90-91 EX 15/16" MC and 3540 Prop valve (keeping rear drums).
__________________________________________
WTB: 90-91 EX 15/16" master cylinder and 3540 Prop valve
Old Sep 18, 2009 | 10:22 AM
Driven's Avatar
Default Re: Brake upgrade on CRX Hf
yes. smaller booster will be fine. it'll just be slightly harder to modulate. the bigger booster provides more "boost", thus allowing less effort to lock up the brakes.
you could run the HF without any problems. but, personally, I swapped to the Si cause I had one laying around. If you can find one for $10, it's worth it, more than that... probably not that big of a deal.
Old Sep 18, 2009 | 11:51 AM
PS122's Avatar
That's good news - one less component I'll have to buy. I've heard that a 4040 prop valve will work (and is more available)... any opinions? If you had rear drums what prop valve did you use?
Old Sep 18, 2009 | 04:51 PM
rallypoint_1's Avatar
Why limit the brakes at 10.3"? Go for 11.1!!
Old Sep 20, 2009 | 08:17 AM
PS122's Avatar
10.3" is quite a bump up from the HFs stock 9.1". My goals are 130-150whp with a sub-2000# curb weight, so 10.3" should be fime (actually Si 9.5"s would be fine - but I can't leave well enough alone...).
BlkslowCRX
Sep 28, 2010 01:12 PM
neozero999
14
Apr 14, 2008 03:03 AM
HandCommand
19
Jan 15, 2006 06:40 PM
Si2See
22
May 4, 2005 04:26 AM
crx1856
Aug 21, 2003 10:56 PM
