JDM BB4 Headlights and HID Question
Old Sep 17, 2009 | 10:50 PM
aragorn1023's Avatar
Icon2 JDM BB4 Headlights and HID Question
I have the JDM BB4 headlights with the h1 & h4 bulbs. I am currently running hyper white bulbs for the h4, but using the conversion harness made for them by passwordjdm it only uses one filament. My question is..when buying HIDs for them I was going to just buy the low beams(h4) for now, and wait to buy hids for the high beams (h1) later, they come in H4 or H4 (hi/lo). Which of these should I be buying or does it not matter. Thanks.
Old Sep 17, 2009 | 10:56 PM
MikeLuder's Avatar
Default Re: JDM BB4 Headlights and HID Question
I don't think it matters but probably the H4 I'd assume.
Old Sep 17, 2009 | 11:02 PM
I wasnt sure if it would or not. I just assumed go with the H4 only, but didn't wanna be spending the cash on hids and not being able to use them. I mean im sure I could modify the pwjdm harness to run the other filament if needed, but would rather go without the hassle.
Old Sep 18, 2009 | 10:30 PM
bump
Old Sep 18, 2009 | 11:38 PM
yohan's Avatar
H4 bulbs are not HID, are you talking about brighter bulbs for your ludes JDM projector housing?
If so, go and buy upgraded H4 writing harness that won't melt, and splice together the high and low so both beams turn on. You'll **** off oncoming traffic but it'll be worth it to see.
If you're talking about doign a hid retrofit, just put the HID projectors in low beam. I'm not certain there is room for bi-xenon hid projectors in the jdm housing.
Old Sep 18, 2009 | 11:41 PM
I'm talking about buying H4 hids as found here http://www.ddmtuning.com/index.php?p...=101&parent=85
they are available in H4 and H4 (Hi/Lo). Thanks
Old Sep 18, 2009 | 11:56 PM
just an fyi. these are the headlights i have http://passwordjdm.com/JDM-BB4-92-96...e-P990C53.aspx
and these are the custom harnesses i have from them (passwordjdm) as well http://passwordjdm.com/PasswordJDM-B...P1768C320.aspx
Old Sep 19, 2009 | 04:40 AM
street_ride14's Avatar
Some bi-xenon projectors are actually smaller than just low-beam projectors, So .. anything will actually fit with proper modifications to your headlights. Venture to the HID-Retrofit world, you'll never go back to Halogen after experiencing HID-Power.
Old Sep 19, 2009 | 02:26 PM
I can't just put hid bulbs in the housing? If they are H4 or H1 for the high beam bulbs cant i just put them in and hook up an HID kit with the same bulbs?
Old Sep 20, 2009 | 01:49 PM
prelude1897's Avatar
you could use just HID bulbs, but you're not going to have as good of lighting performance as you would if you had a RETROFIT done
Old Sep 22, 2009 | 11:58 AM
Ok I'll check out some write-ups on retrofitting and see how easy it looks. If theres a large margin for error I'll try to avoid it. I did think I could just put an HID kit in, but was wondering specifically whether to use an H4(hi/lo) kit or solely H4. I appreciate all the input guys.
Old Sep 22, 2009 | 10:54 PM
Ok thanks a lot I appreciate all your guys' input. That answers my questions in many ways.
Old Sep 23, 2009 | 06:16 PM
vlude99's Avatar
you can't just stick the hid bulb in your regular housing. you have to do the retrofit. if you don't retrofit, you will be blinding everyone on the road. don't just cheap out because you don't want to spend the money. if you are going to do it, do it right!
Old Sep 23, 2009 | 06:20 PM
Retrofit as in what? A projector retrofit?
Old Sep 23, 2009 | 07:47 PM
esedulerp5tenin's Avatar
i found out the hard way from one of the ebay-store-specials, $30 slim ballast HID kit, that there is a difference between the H4 (hi/lo) and just low, and joshua hit the nail on the head.
when i hooked up the hi/low kit, the lows (HID's) wouldn't come on at all, no matter what. when i flicked the stick for the lows to come on, the HIGH beam of the HID kit (H4) came on, then when i flicked the high beams on, my regular high beams (H1) came on as well, in addition to the other high beams.
so i switched the bulbs from my old HID kit to the new one, and voila... perfect.
so you NEED the H4 low kit.
Old Sep 23, 2009 | 08:07 PM
Ok sounds good. Thanks a lot. I was confused as to which one to buy there for a while.
phantomgreyhatch09
Jan 30, 2010 11:43 AM
gtrwerks
Jul 1, 2009 05:08 PM
specialblend154
Oct 14, 2007 04:40 PM
Spoon*EK9
May 23, 2006 02:26 PM
rough_draft
Jun 4, 2004 03:20 AM
