one piece headlights?
is there such a thing as cheap aftermarket one piece headlights for a hatch? not the sedan headlights because i'd rather not go through the struggle of putting them on and i dont have that kind of money anyways! if there is such a thing i'd like to buy some, im tired of my loose corner lights falling or getting stolen.
and if not, any tips on keeping my corner lights on the car? ha
something along the lines of this, but for the hatch model.
%20Large.jpg)
i could care less if they're not glass, as long as they're one piece i'll be happy. and as long they arent rice! ha
%20Large.jpg)
Your corners get stolen? Assuming you have the 88-89 ones, just upgrade them to the newer ones.
I believe you CAN fit the ef2 ones... it is just extra work, and they are expensive.
bummer. alright, thanks!
no i have the 90 corners. someone pulled them out and broke the plastic clip that holds them, so i got a whole bunch of them from a junkyard for the next time someone decides to be a dick. and i also have a problem with them just falling out because they wont adjust right. any help with that?
adjust? they just slide on, and then the one screw holds them on I thought. There should be two clips that the corner slides into, and one screw that attaches it to the headlight bracket. Atleast, that is how my CRX and HB are.
my corners are exactly the same, but they dont exactly slide into those 2 clips, like if they are bent outta shape or something. so because they wont slide in there right, they wont screw on right either and eventually they become loose.
scdarksol
Dec 18, 2003 09:44 PM
