Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Civic
Old Sep 17, 2009 | 06:51 PM
special76's Avatar
New User
Default 2001 Civic
My instument cluster and dash lights does not work when engine is cold. Soon as the car warms up it works. Also my odometer does not work.
Old Sep 18, 2009 | 12:27 PM
ourbloodykisses's Avatar
Default Re: 2001 Civic
check your battery.
Old Sep 18, 2009 | 01:31 PM
kenbo21's Avatar
connection problem somewhere
Old Sep 18, 2009 | 01:55 PM
HONDAPARTSMANMIKE's Avatar
what do you mean cluster not working till it warms up?? are the needles flicking up and down? if so have the battery tested and replaced if necessary.
Old Sep 18, 2009 | 03:56 PM
special76's Avatar
New User
Ok. When im driving all of the dash lights go off then come on again. Yes all of the needles flicker on and off on the instument panel. My odometer reads trip888888 and when i hit the reset button nothing happens. Do I need a new instrument panel cause of the odometer? Or is there a bad connection somewhere?
Old Sep 18, 2009 | 06:42 PM
deff a bad connection. get the battery checked see how that is, then let us know.
Old Sep 20, 2009 | 04:46 AM
def get the battery tested and replaced if needed. seems to me batt is weak at start up and barely starting. the needles flicking up n down is common to a very weak battery
tonyskala
Feb 8, 2017 01:22 PM
Dat EF Doe
Aug 31, 2013 02:53 AM
99civicsi19
Nov 21, 2010 07:57 AM
torinored eh9
15
Mar 9, 2010 04:38 PM
composter7
Mar 10, 2009 06:24 AM
