VX piston in D16a6 block, Compression Ratio?
Old Sep 17, 2009 | 06:37 PM
flaco06114's Avatar
Default VX piston in D16a6 block, Compression Ratio?
OK, Im rebuilding my engine on my turbo 89 4wd civic wagon. Im going to replace my p06 piston with pistons from a vx engine (p07). I would like to know what compression ratio I will be running and if I will run into any problems?
Old Sep 18, 2009 | 07:01 AM
jlicrx's Avatar
Default Re: VX piston in D16a6 block, Compression Ratio?
what head? P07 pistons in D16A6 with D16A6 head and stock gasket will have compression ratio of around 6.7:1
Old Sep 22, 2009 | 08:30 PM
flaco06114's Avatar
wow.. really? , is it worth it or no ?
Old Sep 22, 2009 | 09:38 PM
.Manny.'s Avatar
Touching My Member
that's crazy low
Old Sep 23, 2009 | 03:07 AM
oldschoollove's Avatar
so what head would make good compression with the vx piston cause im run a vx block with a zc 1.6 vtec head ?
Old Sep 23, 2009 | 07:22 AM
jlicrx's Avatar
VX block with ZC VTEC head with D16Z6 gasket will give you compression ratio of around 7.8:1 - with Y8 head on VX block, compression ratio would be around 8.0:1 - the problem is that the VX pistons have a 16.1cc dish
Old Sep 23, 2009 | 07:41 AM
DCRB's Avatar
soooooooo just try to find a vx motor and put some better rods in it and call it a day
Old Sep 23, 2009 | 08:40 AM
Bunger's Avatar
If you want to run boost on them, why not get some Vitara pistons? They will yield slightly high CR than the z1's and they are a LOT stronger. Cheap too!
http://www.zealautowerks.com/dseries.html
Old Sep 23, 2009 | 04:12 PM
so would the vx block with the zc vtec head be good set up for boost
muskrat
Feb 17, 2017 04:35 PM
The DX Rex
Feb 22, 2005 09:02 PM
RockerX
11
Jun 22, 2004 12:24 PM
JSPECHB
Feb 24, 2004 11:49 AM
