failed smog in my 03 ep3...CEL????
Old Sep 17, 2009 | 06:15 PM
peter_b16's Avatar
Default failed smog in my 03 ep3...CEL????
alrite guys..my cars been throwin some cel for awhile and i took my car in for a preinspection...it was a gross polluter..lol...but i managed to get the codes that my cars been throwin from the inspector and it was: p0113, p1298, and p1166..ive checked the codes and found out wat they are..but question is:how do i go about fix "high input/voltage" issues..im askin this cause i realized that there are different codes for "low input"...let me know...
Old Sep 19, 2009 | 09:01 AM
mustclime's Avatar
Default Re: failed smog in my 03 ep3...CEL????
I would guess you have a short some place....pull your ecu fuse under the hood.....this should clear you cels.....
look here for a full meaning to your cel's
http://www.clubrsx.com/clubep3/errorcodes.html
p0113= air intake temp sensor.....look there for a rubbed through wire
p1298= electrical load detector circute low voltage.....you have a short some place.
p1166= air fuel ratio sensor heater circut mailfunction....that by the throttle body...also close to the airtemp sensor....you got to look at those wires around the t/b....
Old Sep 27, 2009 | 07:59 PM
cloumep3's Avatar
check out o2simulator.com (hope that's correct address...) I had issue with 99 Si greddy turbo and I spent less than 20 shipped and DIY install. Passed mine on the second round. hope that helped.
rjmq06
Aug 20, 2010 04:28 PM
civicSF98
Nov 3, 2009 02:33 PM
Draggin99Si
May 3, 2005 01:11 PM
.M.
Mar 11, 2005 08:51 PM
Nocide_Eluded
May 24, 2004 06:12 PM
