valve adjustment on b series motors??
Old Sep 17, 2009 | 04:40 PM
jdm_manny's Avatar
Default valve adjustment on b series motors??
can sum1 tell me how to do a valve adjustment?? cuz my understanding is that you start at tdc with the #1 piston, rotate the crank 180 degrees then go 2 the #3 piston, then again 180 degrees go 2 the #4 piston, then another 180 degrees and go to the #2 piston, and after that go back in the same order to recheck 2 make sure none are loose?
does this sound right??
but ive also heard u can do that order n only turn the crank 90 degrees?
Old Sep 17, 2009 | 05:23 PM
Arct's Avatar
Default Re: valve adjustment on b series motors??
http://www.team-integra.net/sections...?ArticleID=485
just 90°
Old Sep 18, 2009 | 03:13 AM
jdm_manny's Avatar
i dont know. i keep hearing 180 degrees? but is this the right order as 2 how u do a valve adjustment?
Old Sep 18, 2009 | 02:09 PM
ninezeroteg's Avatar
The cam gear will only turn 90 degrees, but the crank pulley will turn 180. I explained the process in another thread just a few days ago. Here: https://honda-tech.com/forums/engine-management-tuning-124/need-help-valve-adjustment-2643128/
Old Sep 18, 2009 | 02:23 PM
Ruben19's Avatar
1,3,4,2 counterclockwise 90° turns
Old Sep 19, 2009 | 12:57 AM
jdm_manny's Avatar
hm ohh ok thnks. 1 thing though i just read ur other post explaining how 2 do it and isnt tdc when the #1 piston is all the way up and the arrows on the cam gears are pointed straight up?
Old Sep 19, 2009 | 01:12 AM
Ruben19's Avatar
^ yes.
try www.c-speedracing.com for more info.
go to the how to section
Old Sep 19, 2009 | 05:14 AM
That's correct.
Old Sep 19, 2009 | 05:33 PM
jdm_manny's Avatar
oh ok but u wrote when u do the #4 piston its gna be at tdc but i thought when u do that piston the arrows are gna be pointed straight down??
Old Sep 19, 2009 | 06:49 PM
TDC is just the position of the piston. Each cylinder's piston needs to be at TDC while you adjust that cylinders valves. Reason being that this is the position where both intake and exhaust valves will be fully closed.
Old Sep 24, 2009 | 12:18 AM
jdm_manny's Avatar
ohh ok i got it. thanks a lot man. the reason i was confused was cuz i was hearing 90 degees and 180 all the time. but i didnt know when u turn the crank 180 the cam gears only turn 90 degrees so now it makes sense 2 me.
Old Sep 24, 2009 | 09:49 AM
kulo's Avatar
Old Sep 24, 2009 | 10:31 AM
follie gatts's Avatar
if you do not have vtec there are holes on top of the cam holders closest to the cam gears. they line up with holes in the cam shafts. you can stick a screw driver in each one and it will lock your cams at piston 1 TDC.
Old Oct 1, 2009 | 05:02 PM
jdm_manny's Avatar
ohh ok. thnks 4 all the responses.
Old Dec 1, 2009 | 07:24 PM
pulgaleakimports's Avatar
super , perfect pics for the job
Old Dec 1, 2009 | 07:35 PM
GagnarTheUnruly's Avatar
You can also see that the cams will be off the rockers at TDC. That's the real reason for setting each cylinder at TDC. So if you can't figure out which one is at TDC for any given cam position, just look at the lobes and figure out which ones are off of the rockers.
JuggerNaut-CTR
Nov 4, 2012 05:54 PM
djhatchtraxxx89
Oct 4, 2006 03:46 PM
Atheist
Aug 10, 2004 07:40 AM
rightandtight
Jan 18, 2004 08:23 PM
integracivic94
Aug 7, 2003 08:47 AM
