EM1 going LST... Got Questions!!!
Old Sep 17, 2009 | 04:31 PM
dragnsi's Avatar
Icon2 EM1 going LST... Got Questions!!!
I spun a bearing in my B16A2 and now got ahold of a B18B built for boost(9:1). I'm going to get the Stock head machined (P&P, Angle Job, Upgrade Valvetrain & Stage 2 Cams w/Gears). I am also going P28 chipped w/Uberdata.
But at this time I don't have the funds to purchase the turbo setup and this is my DD. So I need some insight as how to tune this with no Turbo and what effect it will have (i.e. MPG, HP & Possible Negative Wear if any at all?). Basically a Built LST Longblock w/ NO TURBO!!!
Old Sep 17, 2009 | 05:43 PM
Frost7177's Avatar
Default Re: EM1 going LST... Got Questions!!!
its gonna be pretty slow.
Old Sep 18, 2009 | 12:01 PM
dragnsi's Avatar
ttt
Old Sep 18, 2009 | 12:20 PM
pvt_awol's Avatar
well, an LS block is already running a conservative 9:1 compression. The headwork will bump your power a bit, but you didn't say what "stage 2" cams you're going to use. I assume they are turbo cams.
THAT is where you are going to lose a bit of power without a turbo. Generally, if you build the motor, but run a stock map, your power and MPG will be about stock. Your's will be no different. However..... those cams. Those are going to make you lose some power, and also affect driveablilty. If tuned right, it'll run a bit rich for those cams, so your fuel econ is going to suffer a bit.
Also, what injectors are you planning to use?
Old Sep 18, 2009 | 12:22 PM
pvt_awol's Avatar
How about this, don't do the headwork yet. Run a stock head for now. Run a stock ECU, or stock base map, and just have a little LS swapped civic for now.
Old Sep 18, 2009 | 12:46 PM
dragnsi's Avatar
Thanks for the INFO!!! Exactly what I needed!!!
Old Sep 18, 2009 | 04:08 PM
solo227's Avatar
Or take it one step further and use that extra money towards getting the car turbo'd... LOL
Old Sep 18, 2009 | 04:35 PM
dragnsi's Avatar
Already have parts and machine work is at a steal... plus engine is already torn apart and dont want downtime later waiting for machining..... HENCE MY DD!!! Thanks for INPUT!!!
rudebwoy
Nov 26, 2014 06:30 AM
GsDAteg
Mar 18, 2006 11:20 AM
B18 rider
Aug 4, 2005 09:12 PM
BodyKits NW
Apr 11, 2005 08:21 PM
InfamousRS
Sep 10, 2004 02:17 PM
