instrument panel light not working so is the tail lights...bulbs are good and so is fuses..where sho
I re-tightened a ground sensor thatwas loose and now my cluster, ac panel light are not working so is my tail lights...
I checked both fuses are okay...
so what is the problem ?
where should I start to look ?
TIA
TIA
I know on some american cars, when the rear tail lights go out, so does your dash. Its an indicator so that you know your rear taillights are out.
Did you try changing your tail lights?
check all the fuses again, even the ones that are not indicated as the tails and the dash. That happened to me when I first wired my sidemarkers and I checked the fuses, but not all of them and it ended up being like the tail light fuse.
TTT, the tail lights fuses kept burnign out, put a 20Amp fuse there, didn;t blew it but still not working....
the cluster light is still not working...bulbs is good....
WTF...
WTF...
88aeFC3S
Jan 3, 2010 11:38 AM
