I need help with my 89 civic hatch wiring
Old Sep 17, 2009 | 03:01 PM
Dregonomics's Avatar
New User
Icon2 I need help with my 89 civic hatch wiring
i need help with the in-dash wiring.if any one has a stock wiring diagram or would help me out would really appreciate it.i have a dx and im using a ef si wiring harness so if any one would help me out would really really be gratefull.wanna hear my car start already ;/ btw i looked around for a very long time for this diagram and came across nothing.or any help with my problem.
Old Sep 22, 2009 | 11:00 AM
sapix_'s Avatar
Default Re: I need help with my 89 civic hatch wiring
I know for sure you will get the diagram in carolinahondas.com; not sure exactly where but I am sure I've seen it there.
Old Sep 23, 2009 | 10:56 AM
New User
thanks man i have been waiting for some one to answer me. I found out that my engines not getting no spark or gas.any suggestions as to what that could be?
Old Sep 23, 2009 | 11:15 AM
sapix_'s Avatar
not spark or gas? one or the other or both? uhmmm first thing that comes to mind is the fule pump if it is not getting gas. does the starter work? Can you just crank it but it just does not start? or does not even crank?
1. check fule pump
3. check distributor and distributor wires (make sure it generates sparks)
4. check fule pump fuse
5. check main relay
too little information to better help you but those 5 things will at least give you a broad idea of what it could be wrong if any of those is not working.
Old Sep 23, 2009 | 11:47 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Why in the world are you doing a harness swap? It is MUCH easier to just use the DX harness... you are crazy...
Old Sep 23, 2009 | 04:50 PM
New User
well look here is the problem i bought the car with that harness.and i dont have the money to buy the original.so im using what he has.the car has no spark and there is no gas going to the engine.to check if no gas is coming out i loosend the bolt from the gas hose and cranked it.got out and nothing was there.i bought a new distributor and wired it all up so thats new.i replaced the main relay.the only thing i havent checked was the fuel pump fuse which i will check.the car cranks just dont turn over...and im stumped on what to do.ill try to check the fuse and see what happens.there are a few wires from the indash that are not connected.if it will help i will take some pics tmorrow.ill even put a vid of how it looks when i crank it and so on.
Old Sep 23, 2009 | 05:16 PM
D16SiHatch's Avatar
so are you using both the si cabin and engine harness?
Old Sep 27, 2009 | 07:54 PM
New User
yes.and yes.
CanadianEF9
11
Jul 27, 2011 06:37 AM
beana
Jun 15, 2009 10:00 AM
EF_GUY
Feb 4, 2008 08:58 AM
EF'n
May 22, 2003 10:16 AM
