alternator problem
Old Sep 17, 2009 | 07:09 AM
88 EF Hatch's Avatar
Default alternator problem
you guys this is weird, so my battery light came on so i figured my alternator was bad, i went and checked for voltage on my battery when car was running and it was only at 12V, normally its at 13-14V when my car was running, battery and alternator are both relatively new, so i took it to autozone to test battery and it was good, on alternator test it said low output. so Could my alternator be bad or is it maybe the wiring?
Old Sep 17, 2009 | 07:29 AM
dephtone's Avatar
Default Re: alternator problem
Well if it has low output then more than likely the brushes inside are going bad. Return it to where you got it from if it has a warranty.
Does the battery light come on when you have lights and other accessories on? If so, your alternator is on it's way out as it can't keep up with the voltage being used.
hondastrtracr
16
Jan 27, 2008 09:16 PM
aziaticvang
Jan 7, 2008 03:59 PM
deeice30
Dec 13, 2005 11:37 AM
hondaracin24
May 30, 2005 08:17 PM
EG6[B16A1]
Jun 28, 2003 09:03 AM
