need tips 2now how 2change timing belt and water pump with a broken pully
Old Sep 17, 2009 | 06:18 AM
gr3g787's Avatar
Icon6 need tips 2now how 2change timing belt and water pump with a broken pully
I have a 93 honda civic dx and I need 2 change water pump and timing belt but my pully screw is rusted on 2tha motor if I try 2take it out its goin 2 mess up tha motor. Need some tips help
Old Sep 17, 2009 | 06:25 AM
RxglassJAw's Avatar
Default Re: need tips 2now how 2change timing belt and water pump with a broken pully
you're very creative at using "2"s in sentences...
found this...
http://www.denlorstools.com/home/dt1...pful_tips.html
Old Sep 17, 2009 | 06:31 AM
honda.lioness's Avatar
-- Apply PB Blaster a few times over a week, driving the car in between applications. The bolt heats up some while driving and this will help the PB Blaster soak into the threads.
-- Get the right pulley holding tool offered at places like Ebay and Amazon for around $25-$40. (The one in the denlorstools link above is not the right tool for the 93 Civic DX, though the tips in general look okay.) Use a 5-foot pipe extension on your breaker bar. Use at least a half-inch drive 17 mm socket and extensions. 3/4-inch is preferable but then the tools are much more expensive. I have always had success with 1/2-inch, but there is around 50 degrees of wind-up involved when the bolt is really tight, so be careful as you apply torque with that 5-foot pipe.
-- Attempt to loosen shortly after running the car awhile. This way, the bolt is still hot and should be stretched from heat expansion some, meaning it should be at least a bit easier to free.
Tina Saunders
Jan 21, 2013 10:37 PM
GREG787
Dec 10, 2008 06:14 PM
therivler1
Jan 11, 2008 08:07 PM
soaggydogg
Oct 31, 2005 04:48 AM
89hbcivicguy
Mar 18, 2005 07:44 PM
