F/S Built LS part out Crower, AEM, Mishimoto, Eagle OBO!!!
Contact Info::
Phone Number:864-978-8367
1. got a built ls bottom end i jus bought from someone and paid 600 for but i got jipped the block is messed cuz the dumbass didnt put thrust washers in and the crank scarred up the block and main caps up but pistons rods and crank is still good its got eagle rods wit the big bolt upgrade and arias 81.5mm pistons 9:1 comp and micropolished crank and block guard my loss is your gain and also the machine shop said the block could still be used after some machine work
Bottom end 400$ OBO
2.built ls head jus had it resurfaced got crower valvetrain crower 404's aem tru time camgears the intake manifold is stock but port matched to a 70mm tb and a hondata im gasket that also comes with it its got new valve seals and ill even throw in a set of arp head studs that have been torqed down twice and a new oem headgasket
Head: 650 pretty firm on that
3. got a b series fidanza 7.5lbs flywheel needs new friction plate
$50
4.i got 2 ls ys1 cable trannys one has carbon coated syncros in 3 and 4 but also grinds in 3 and 4 and the second tranny has a very slight 3rd gear grind
$200 for both trannys Firm
5. also have an ls oil pump with only like 5 miles on it
$80
6.mishimoto intercooler rated 32psi good condition got a few dings but wnt affect the flow
$100
Bottom end 400$ OBO
$50
$80
$100
allmotaeg6
Northern California (Sales)
25
Oct 18, 2010 09:58 PM
spooledex
Jun 11, 2009 06:07 AM
NaIsGay
Mid-Atlantic (Sales)
14
Apr 16, 2009 07:35 AM
Irishweird00
Jun 1, 2003 05:37 PM
