b16a head reassembly
Old Sep 17, 2009 | 05:33 AM
SickSi99's Avatar
Default b16a head reassembly
i got my b16a head partially built but they didn't reassemble everything after the partial build. so i'm going to put it back together myself. really just need the torque specs on the cam cap bolts and what i need to reinstall the cams and cam seals. do i need some kind of sealant around the same seals and how much is needed?
any help would be appreciated. i'm gonna drop my skunk2 stage 1 cams in it with the skunk2 cam gears and skunk2 cam seals. thanks.
Old Sep 17, 2009 | 05:50 AM
kyden's Avatar
Default Re: b16a head reassembly
grab a helms manual.
Old Sep 17, 2009 | 06:05 AM
SickSi99's Avatar
i'd rather do it the free way first.
Old Sep 17, 2009 | 07:45 AM
1.5Slowmatic's Avatar
you can get them online as well as factory service manuals if you try google
Old Sep 17, 2009 | 11:14 AM
Langford360's Avatar
all the 12 mm bolts for the cam caps are 20 foot lbs the 10mm are 7.2 foot lbs and for the cam seals remove the cam gears and slide them spring side toward the head and i believe the factory cam shaft trq for the cam gears is 41 foot lbs. if you are using any other cam beside a factory cam use that cam shaft trq spec for the cam gears
Old Sep 17, 2009 | 11:18 AM
Also get some honda bond and place some on the flat surface on each side of the cam seal once they are placed in the head.
Old Sep 17, 2009 | 11:59 AM
SickSi99's Avatar
thanks man. thats what i was looking for. can honda bond be substituted for a different type of sealant?
Old Sep 17, 2009 | 12:47 PM
yeah im sure but its all i ever use. u can prolly pick it up for 14$ at honda. it will last you a long time also.
ahobbs
Texas -OK -LA (Sales)
Oct 13, 2009 02:32 PM
robcrx
Apr 9, 2006 07:35 PM
Reis
Jul 20, 2005 02:44 PM
rough_draft
Mar 26, 2005 05:32 PM
the_eyecon
Apr 25, 2004 06:05 PM
