Transmission & Drivetrain Gearboxes, Differentials, Clutches
5 speed 99 honda odyssey
Old Sep 17, 2009 | 04:48 AM
adamrich33's Avatar
Default 5 speed 99 honda odyssey
can it be done or better yet has it been done, im getting tired of this junk *** automatic,
Old Sep 18, 2009 | 05:58 PM
94EG8's Avatar
Seagull Management
Default Re: 5 speed 99 honda odyssey
I keep hearing an Accord/TL 6 speed tranny should work. At this time I can't find a link saying it has been done, but i'm quite sure it has been done a few times and I have very little doubt that if it hasn't been done yet it can.
Old Sep 20, 2009 | 01:57 PM
adamrich33's Avatar
if theres a trans that will bolt up and work, the rest will just be fab work. if anyone has any more info pleasae let me know
Old Sep 21, 2009 | 07:43 AM
hondamark35's Avatar
there's no reason i can think of that would keep you from bolting one in. the mounting may not be straight foreward. it's likely you'll need the Type-S mounts, or even custom mounts... if you can get your hands on a Type-S for an hour or so some carefull measurements to compare to the odyssey should give you an idea of what is needed in that respect.
my question: where would you put the shifter? it would be awkward on the floor... on the dash maybe?
Old Sep 21, 2009 | 05:32 PM
adamrich33's Avatar
maybe a mack truck shifter.lol. the shifter would be the hardest of it all, are the type s trans cable shift
my question: where would you put the shifter? it would be awkward on the floor... on the dash maybe?[/QUOTE]
Old Sep 21, 2009 | 05:34 PM
adamrich33's Avatar
what year type s are you thinking will bolt up
Old Sep 21, 2009 | 06:01 PM
'02 and up is when the Type-S started... so i'd imagine you'd want to start looking there. in '05 it went from a 5spd to a 6spd if my facts are straight.
Old Sep 22, 2009 | 06:03 PM
adamrich33's Avatar
im not to sure a TL trans will work, they are 3.2L and my Ody is 3.5L though the 07-08 TL type S is a 3.5L, but all are J series engines,
Old Sep 23, 2009 | 03:15 AM
displacement doesn't change the transmission bolt pattern.. also, the power output isn't much different (by that i mean you won't break anything with excess mini-van power) i would imagine there is just more low end torque in the 3.5.
all J-series trans should interchange.
Old Sep 23, 2009 | 04:12 AM
94EG8's Avatar
Seagull Management
J-series are cable shift.
Put it on the floor, Dodge caravans, ford aerostars, and VW Eurovans all used to be available as a manual, all had a floor shift, really wasnt akward to use, just looked that way. (just as an fyi dodge actually used to have a 2.5L turbo caravan for '89 - '90 that in rare instances came paired with a 5 speed, fun grocery getter)
Old Sep 23, 2009 | 06:50 AM
adamrich33's Avatar
thanks for the info, but know looking at the price of TL trannys compared to a rebuilt auto with a warranty im kind of second guessing myself, if i could only see a write up on it i would jump all over it, its a bit overhelming to think of doing this with out any type of resources,
Old Sep 25, 2009 | 06:58 PM
adamrich33's Avatar
i found a lap of america video with bradley buchanan a driver and builder from Honda of Alabama. They have TL manual trans in there odyssey, so it is definetly do-able but the video does not go into detail about trans mounts or axles
bighoss77
Sep 3, 2012 12:01 PM
zerovandez
11
Jul 22, 2010 10:51 AM
chicows18
K Series
Apr 7, 2010 07:27 AM
Blacksheep0272
Mar 8, 2010 08:35 AM
