Rev Engine and then let off gas, and Valve Noise??
Old Aug 27, 2002 | 06:41 PM
Comptech98GSR's Avatar
Default Rev Engine and then let off gas, and Valve Noise??
just did my valves about 500 miles ago, now my valves are still making noise in the morning, when the engine is cold, they make a tapping noise, and when i rev the engine and let off, they make a high pitch noise also, did i adjust my valves wrong or something??
Old Aug 27, 2002 | 06:44 PM
01-1293's Avatar
Default Re: Rev Engine and then let off gas, and Valve Noise?? (Comptech98GSR)
i hear theses noise all the time.........i'm not saying there is nothing wrong........it seems like i always think sometyhing is wrong with my R...........i've never been in a car that sounds anywhere near as raw as the R........
Old Aug 27, 2002 | 06:49 PM
Default Re: Rev Engine and then let off gas, and Valve Noise?? (01-1293)
glad at least someone is there with me, anyone know a solution to this?
Old Aug 27, 2002 | 07:15 PM
integratom's Avatar
Be sure the motor was dead cold when you did it and recheck it when its cold, also be sure you used the right size feeler guages its .17mm int .19mm exh. or .006in and .007in you can go 1 size smaller safely and it will quiet them some more and could be worth a few HP at cost of a slightly rougher idle. HTH
Old Aug 28, 2002 | 12:16 PM
Default Re: Rev Engine and then let off gas, and Valve Noise?? (integratom)
are those GSR specs or R? .006 intake, .007 exaust?
Old Aug 28, 2002 | 12:18 PM
Reid's Avatar
Global Moderator
ITR.
This is the ITR forum, after all.
Old Aug 28, 2002 | 12:20 PM
Dave-ROR's Avatar
Default Re: Rev Engine and then let off gas, and Valve Noise?? (Reid)
The specs are also located on a sticker under your hood iirc. i don't look anymore.
Old Aug 28, 2002 | 12:31 PM
AssPenny's Avatar
Default Re: Rev Engine and then let off gas, and Valve Noise?? (SoFreshAndSoCleanClean)
My valves make cool funky noises when say I'm in gear but not on the gas (ie engine braking). Sounds kinda funky, but its always done it. Thats what the radio is for.
Old Aug 28, 2002 | 12:34 PM
TsunamiZC's Avatar
Default Re: Rev Engine and then let off gas, and Valve Noise?? (AssPenny)
mine does that tooo...i guess thats what happens when ya got no sound deadening
Stevo F
Jul 14, 2014 07:25 PM
sp00led
Sep 13, 2004 06:09 PM
rickytz7111
Jan 1, 2004 11:00 AM
Comptech98GSR
Aug 27, 2002 08:55 PM
BryanS
Sep 25, 2001 10:46 AM
