200k mile tune up
Old Sep 16, 2009 | 09:11 PM
7mile's Avatar
Default 200k mile tune up
I had the car for one year now, time to get a full tune up since i put 50k miles on it. (major commute)
what do you recommend?
2000 honda accord ex.. since i bought the vehicle i only did normal oil changes, and had to replace the bad o2 sensor.
wanted to know what should i replace at 200k miles.
thanks
Old Sep 17, 2009 | 03:33 AM
hondamark35's Avatar
Default Re: 200k mile tune up
if the first timing belt was done at the right time (around 105k miles) you're about due again.
things i would do..
-oil change
-trans fluid change
-air filter change
-replace spark plugs, wires, cap and rotor
-cabin filter
-check tires for wear and pressure, rotate if needed (don't forget the spare)
-check brakes (including fluid condition, change fluid if needed)
-check hoses for cracking or buldging
-check accessory belts for cracking or abnormal wear (i use this as an indication of timing belt age since they should be changed at the same time)
-hit all the hinges and latches with some white lithium grease
-check p/s fluid (if equipped)
-check coolant level and condition
-clean battery and battery cables
-clean engine bay
i know i'm leaving something out, but this is close enough to complete.
Old Sep 17, 2009 | 03:45 AM
djkurious's Avatar
I would also check the ball joints for cracks. Very inexpensive to replace.
RickyDayz
Oct 30, 2014 02:26 AM
colombian_accord
Jan 19, 2006 11:28 AM
Ms.JDMdb8
Jul 9, 2005 06:34 AM
.M.
Mar 25, 2004 08:16 AM
Campee
Apr 2, 2003 09:32 AM
