Woble in the front end
Old Sep 16, 2009 | 07:57 PM
ERKK's Avatar
Default Woble in the front end
I have a 1990 hatch Si with a b16a in it now. Everytime i ht the gas my front end will shack like something is off balance and its not my tires i got them balanced i dont know what else it could be.
Old Sep 17, 2009 | 06:57 AM
90civichbsi's Avatar
Default Re: Woble in the front end
DId it start when you did the swap? did you take the dust rings out of the knuckles before installing the axles? that will cause vibration under acceleration if you didnt take them out.
Old Sep 17, 2009 | 08:42 AM
.Manny.'s Avatar
Touching My Member
get under there and triple check every bolt you tinkered with during the swap, that is if you did the swap. check either way.
Old Sep 17, 2009 | 10:11 AM
89LSED's Avatar
Worn out CV's will also do that. I had mine do that for about a day couldnt figure out what it was then... SNAP!! there went the driver axle. New axle and no more shake
Old Sep 17, 2009 | 03:16 PM
ERKK's Avatar
how can i check if thats it with out replacing it? all my axels are like 4 months old
Old Sep 17, 2009 | 09:39 PM
ERKK's Avatar
bump
Old Sep 18, 2009 | 07:44 AM
ERKK's Avatar
bumppp
Old Sep 18, 2009 | 07:52 AM
it would more than likely be making a clicking noise on turning one way or the other if it were your axle.
Did you ever see if you still have the dust rings installed on your knuckles? When I did my first swap a long time ago I forgot to take one of them out and had a bad wobble on acceleration.
Old Sep 18, 2009 | 07:55 AM
akshn1's Avatar
check the rear mount..this has happen to me before.....maybe not bolted right
Old Sep 18, 2009 | 03:00 PM
89LSED's Avatar
It was wierd. mine wernt popping at all, just started to shake. But i broke mine on Inner joint, the one at the halfshaft. I blew that thing APART!! many many many differient pieces. I think thats why it didnt pop at all, because the inner doesnt angle as sharp s the outer CV. As for inspecting them, you could take the front out of the knuckle and then rotate and wiggle the axle while you have a hand on the inners. Just listen for noises and feel for "Un-smoothness" haha i couldnt think of the right word.
griz50cal
May 5, 2007 07:22 PM
delsolnewkid
Jun 17, 2006 07:49 AM
CleanHatch
10
Oct 23, 2005 09:52 PM
david90
Jun 15, 2004 03:33 PM
cjames235
13
Aug 22, 2003 04:50 AM
