are koni/ground control ajustable?
yes koni yellows are 5 way adjustable, koni reds are not, yellows also have 2 height adjustments with the spring perch, depending on where you put it
Koni Sports (Yellows) are 1 way adjustable. They adjust rebound. They also have no stops in the adjuster sweep, allowing you to set them to any intermediate setting between the range ends, unlike a typical "5 way" adjustable shock (quotes, because there is no such thing in reality, its marketing speak).
Yellows have either 2 or 3 circlip locations (or 5 for the Neuspeed rebranded ones), depending on car model and which shock (front or rear).
However, the more important question is, why do you think you need adjustable shocks?
i have 17" wheels with 215 40r"s on now so i couldent slam it as i planed my wheels couldent turn cause there to big. im getting 16s soon then i can drop it. but i had 1.5 inch drop befor from eibachs. but it gave me around 3" of travel ill be sure to post some pics once i get new wheels.
