Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Quick Ecu Question
Old Sep 16, 2009 | 02:31 PM
zccivicex's Avatar
Default Quick Ecu Question
are the ecu interchangeable between 01-05? or what years are they?
Old Sep 16, 2009 | 04:53 PM
zccivicex's Avatar
Default Re: Quick Ecu Question
i know someone knows this!
Old Sep 16, 2009 | 05:24 PM
Igaly's Avatar
why would you wanna swap ecu's? they r all the same...
Old Sep 16, 2009 | 05:30 PM
julezeve's Avatar
yes they are.
but if you have an Ex you have to get the EX ECU or your Vtec won't work.
LX and DX don't have Vtec.
katzenjammer84's Avatar
Maybe he has a bad ECU and is junkyard hunting? It's a common problem believe it or not, thanks to Honda grounding the alternator.
Yes, they are all the same.
Old Sep 16, 2009 | 05:31 PM
julezeve's Avatar
maybe his ECU is broken
Old Sep 16, 2009 | 05:39 PM
zccivicex's Avatar
from 2001-2005? and yes the ecu went bad.
Old Sep 16, 2009 | 05:42 PM
julezeve's Avatar
yep 01 - 05 will work.
Old Sep 16, 2009 | 05:43 PM
zccivicex's Avatar
okay thanks alot....now i just gotta find a place that has a 5speed ecu!
Old Sep 16, 2009 | 05:46 PM
julezeve's Avatar
keep in mind when you get the ECU you will have you get the key reprogram or your car won't start or unless you find a way to by-pass the immobilizer then you are all good(Which is what I am trying to do but I think i will end up taking it to the dealer and getting the key reprogram).
Old Sep 16, 2009 | 05:47 PM
julezeve's Avatar
there is a guy in civicforums selling one for $75 if you want i can IM you the link
Old Sep 16, 2009 | 10:07 PM
Manny 77's Avatar
Make sure if you have vtec to get an Ex or Si (MODEL) ecu and if your car is a Dx or Lx then get that ecu and if your car is automatic you have to find a ecu from an automatic same if is manual have to be a manual ecu... if you used an automatic ecu on a manual car the car will work but the check engine light will come on...
Old Sep 17, 2009 | 03:25 AM
zccivicex's Avatar
ya if you will post the link that would help!!
Old Sep 17, 2009 | 07:23 AM
julezeve's Avatar
sent you an IM.
Old Sep 17, 2009 | 07:33 AM
bomerman19's Avatar
04-05 ecu is differrent from 01-03 ecu
Old Sep 17, 2009 | 09:57 AM
julezeve's Avatar
what makes the 04-05 ECU different from the 01-03??
they are all the same Engine/same tranny.
the only thing that I am aware off is the keys are laser cut from the 03-05 compare to the
01-02.
Old Sep 17, 2009 | 01:56 PM
bomerman19's Avatar
01-02.
o2 sensor's the 01-03 dx, lx, and ex use a narrow band o2 sensor were the 04-05 dx, lx, ex, and the 01-05 hx use a wide band o2 sensor. so the pin out's on the ecu plugs are different
I think there also might be a couple other things that they changed in the harness for the 04-05 but I never looked into since the only thing that concerned me about the 04-05 was trying to use that to do a wideband conversion on a 01-03
here this might help
http://www.hondata.com/kpro_d17.html
Old Sep 17, 2009 | 02:22 PM
julezeve's Avatar
^^ good info learn something new everyday...I've heard something about the clusters being wired different but never knew they change the 02 sensors.
Old Sep 22, 2009 | 09:37 AM
Igaly's Avatar
wich SI ecu fits the EM the EP?
Old Sep 29, 2009 | 07:53 AM
SONER-VTI's Avatar
He can use his original ecu's immo eprom. We did it so. Remove immo eprom from the ex-ecu, then install it to the new ecu.. that's all...
Old Sep 29, 2009 | 08:14 AM
2002civicrider's Avatar
He's referring to the canadian si which is the us ex i believe.
Amber Rock
Jan 25, 2016 08:38 AM
reenot
Jan 18, 2011 06:12 PM
nick91civicsi
Engine Management and Tuning
Oct 25, 2009 03:27 PM
_HANS
Jun 13, 2004 03:33 PM
