CA 85 CRX Race Car UPDATE!
Old Sep 16, 2009 | 02:01 PM
siguy2's Avatar
Default 85 CRX Race Car NEW LOWER prices!!
I am parting out my 6 year project or the entire car all together! The motor has 5 passes at the track and approx. 30 dyno pulls which made 350 whp. LMK if you would like anything on the car. I am going to put up a couple pics, but there is to many parts to list. All prices are wanted and negotiable! I am going to leave my phone number and email, because that is the easiest way of getting ahold of me. 559-679-2055 or cnk4eturn@hotmail.com
Update NEW LOWER pricing (items with *)!!! pics on a requests basis and some items are pick up only.
*-2.2 liter B20 botttom end with 95mm crank, manley rods, circuit works oil pump, and custom JE pistons (block has 4 half track passes) $1200 pending sale!
*-93 integra YS1 tranny with all new seals, gears, and bearing with Quaife LSD $1000
*-LS Vtec line kit $60 sale pending!
*-Ken's Custom chassis wheelie (bars twin wheel design, brand new, never been mounted!!) $450
*-NOS 15 lbs. nitrous bottles filled with nitrous pressure guages and switches (I have 3) $175 each
*-Spearco intercooler 30x3.5x10.5 (brand new) $300
*-GSR throttle body (cable bracket, map and TPS sensor included) $30
*-DSM 440 injectors with resistor box $50
*-92-95 EX 2 door facotry wing with factory wiring $50
SOLD ITEMS:
*-Skunk cam gears SOLD
*-Custom Web Cams (12mm of lift and 319 degrees of advertised duration IN cam) SOLD
*-B16 head custom port job by Vernon at Raver motorsports with Vtec solenoid and custom powder coated valve cover! SOLD
*-Ferrea valve springs and retainers SOLD
*-SI stainless steel 1mm oversize valves SOLD
*-Bosch 1600cc injectors $200 SOLD
-OBD 1 B16 distributor SOLD
-ARP head studs SOLD
-scatter shield SOLD
-Walbro 255 liter high pressure fuel pump SOLD
*-2 Gallon fuel cell with brackets SOLD
*-catch can with breather SOLD
-26x8.5x13 M&H slicks (brand new) SOLD
-24x3.5x15 front runner skinnies (4 passes at the track) SOLD
-Bogart rims 13x8.5 GSR spacers SOLD
-Bogart rims 15x4 skinnies SOLD
-P28 computer with hondata S300 SOLD
-ATI dampner (brand new) SOLD
-Stanley parachute (brand new) SOLD
*-Clutch Masters twin disk clutch 4 passes on the track SOLD
*-JG Fab top mount exhaust manifold with T4 flange SOLD
*-Turbonetics GT42R single ball bearing .78AR with P-trim wheel (brand new) SOLD
*-Turbonetics swing valve wastegate 60mm SOLD
*-Turbonetics Godzilla BOV SOLD
-RPM 76mm throttle body SOLD
-AEM 5 bar map sensor SOLD
-****SMOKIN DEAL****-85 CRX Chasis with custom 10 point cage with front end caged for B or D series motors. The wiring is complete and has a rear safety switch. Drop in a motor and go. Custom stage 4 Drive Shaft Shop axles. GSR front and rear brakes with EBC pads and Brembo rotors. Lexan windows with tow clip. set up for parachute and wheelie bars. has Tokico shocks with Eibach springs and custom pan hard bar with traction bar mounts. MSD 6AL box with 2 step and blaster coil. Guages included are tach, oil pressure and temp, water temp and voltage. Rear hand brake with line lock. custom fiberglass front end SOLD
And if you are wondering I know the pics are all sideways. Don't have time to fix them. Sorry! LOL
Old Sep 16, 2009 | 05:58 PM
srt4mike's Avatar
Default Re: 85 CRX Race Car
Old Sep 17, 2009 | 01:59 PM
siguy2's Avatar
TTT
Old Sep 18, 2009 | 02:11 PM
siguy2's Avatar
TTT
Old Sep 19, 2009 | 03:17 PM
siguy2's Avatar
TTT
Old Sep 21, 2009 | 06:42 PM
siguy2's Avatar
Update individual pricing!!! Prices are always negotiable, but please make a reasonable offer. pics on a requests basis and some items are pick up only.
(Ferrea valve springs and retainers with SI stainless steel 1mm oversize valves) $700
-2.2 liter B20 botttom end with 95mm crank, manley rods, circuit works oil pump, and custom JE pistons (block has 4 half track passes) $1500
-93 integra YS1 tranny with all new seals, gears, and bearing with Quaife LSD $1500
-Custom Web Cams (they are copies of TODA stage 3) $300
-Skunk cam gears $50
-AEM 5 bar map sensor $75
-ARP head studs $40
-LS Vtec line kit $70
-Clutch Masters twin disk clutch 4 passes on the track $800
-JG Fab top mount exhaust manifold with T4 flange $700
-Turbonetics GT42R single ball bearing .78AR with P-trim wheel (brand new) $900
-Turbonetics swing valve wastegate 60mm $250
-Turbonetics Godzilla BOV $150
-Ken's Custom chassis wheelie (bars twin wheel design, brand new) $800
-26x8.5x13 M&H slicks (brand new) $300
-24x3.5x15 front runner skinnies (4 passes at the track) $150
-Bogart rims 13x8.5 GSR spacers $350
-Bogart rims 15x4 skinnies $200
-NOS 15 lbs. nitrous bottles filled with nitrous pressure guages and switches $200 each (I have 3)
-2 Gallon fuel cell with brackets $50
-catch can with breather $40
-Spearco intercooler 30x3.5x10.5 (brand new) $500
-GSR throttle body $30
-Bosch 1600cc injectors $250
-85 CRX Chasis with custom 10 point cage with front end caged for B or D series motors. The wiring is complete and has a rear safety switch. Drop in a motor and go. Custom stage 4 Drive Shaft Shop axles. GSR front and rear brakes with EBC pads and Brembo rotors. Lexan windows with tow clip. set up for parachute and wheelie bars. has Tokico shocks with Eibach springs and custom pan hard bar with traction bar mounts. MSD 6AL box with 2 step and blaster coil. Guages included are tach, oil pressure and temp, water temp and voltage. Rear hand brake with line lock. custom fiberglass front end $4000
Old Sep 22, 2009 | 07:28 AM
siguy2's Avatar
Default Re: 85 CRX Race Car UPDATE!
intake manifold and fuel rail sold!!
Old Sep 22, 2009 | 10:54 PM
siguy2's Avatar
TTT
Old Sep 23, 2009 | 12:07 AM
ALLxMOTOR EG's Avatar
Vietnamese!
1st gen crx are way lighter then 88-91 model, i bet this car moves at the track!
Old Sep 23, 2009 | 06:37 AM
siguy2's Avatar
1700 lbs. with 185 lbs. driver in it! BAD ***. First launch w/0 wheelie bars 1.48 on 24 inch tall slicks and only 350 WHP.
Old Sep 23, 2009 | 07:08 AM
theidealone's Avatar
Bump for you sir.
Old Sep 23, 2009 | 04:31 PM
siguy2's Avatar
TTT
Old Sep 24, 2009 | 04:33 PM
siguy2's Avatar
TTT
Old Sep 25, 2009 | 08:16 PM
siguy2's Avatar
Update items sold!
Old Sep 26, 2009 | 08:47 PM
siguy2's Avatar
Updated!
Old Sep 28, 2009 | 03:02 PM
siguy2's Avatar
TTT
Old Sep 28, 2009 | 04:13 PM
93supercoupe's Avatar
sick car
Old Sep 29, 2009 | 06:44 PM
siguy2's Avatar
Update! cam gears and ARP studs pending payment!
Old Sep 30, 2009 | 05:06 AM
siguy2's Avatar
UPDATE!
Old Oct 1, 2009 | 01:36 PM
siguy2's Avatar
NEW lower prices!!
Old Oct 4, 2009 | 06:03 AM
siguy2's Avatar
New items added and updated sold items!!!!!
Old Oct 5, 2009 | 05:15 PM
siguy2's Avatar
TTT
Old Oct 7, 2009 | 03:35 PM
siguy2's Avatar
TTT
Old Oct 11, 2009 | 03:28 PM
siguy2's Avatar
TTT
Old Oct 15, 2009 | 01:31 AM
siguy2's Avatar
TTT
