need help pulling out stock motor, cant figure somethings out. need help
Old Sep 16, 2009 | 12:55 PM
jdmeg21's Avatar
Default need help pulling out stock motor, cant figure somethings out. need help
Hey guys I'm pullin out the stock sohc non vtec out of my crx. I have a couple questions about taking some things off or Apart.
First - There is a cable running from the center of the firewall to the back of the tranny, it is a thick black cable seems to be a speed sensor or something. well I don't know how to take it off. I'm kinda stuck here.
Also How do I take off the shift linkage from the tranny I can just do it from the shifter and middle of the car, but then I have to pull the motor out with it still attached to the tranny. I know its a pin of some kind but cant seem to figure out how to remove the pin.
other then that motor is ready to pull out so if you guys could help out with the info that would be great and get things moving for me again
Old Sep 16, 2009 | 12:59 PM
dephtone's Avatar
Default Re: need help pulling out stock motor, cant figure somethings out. need help
1. The cable is the speedometer cable, just pull back the black rubber thing, there is a little C clip that holds it in the trans, it will pull right out.
2. There is a "bitch pin" in the linkage right before it connects to the trans, easiest way to get it out is to get a 1/4" extension and smack it with a hammer, it will come out.
Old Sep 16, 2009 | 02:18 PM
sde780's Avatar
i just dropped my shifter from the car and took it out with my tranny. however i did the drop-motor method, i didnt use a hoist. Be sure to keep the clip safe from the speedo cable, i had a hell of a time finding another one
Old Sep 16, 2009 | 02:22 PM
b18cKoupe's Avatar
, one of the four bolts holding the ac compressor has a point on the end of it, it fits perfect for punching the roll pin out. THAT IS THE EASIEST WAY WITHOUT THE PROPER 8MM PUNCH.
Old Sep 16, 2009 | 05:42 PM
thirty5hertz's Avatar
Ya dont put that crappy pin back in when you put your swap back together get you a bolt and nut and washer and use it instead. Damn you barrel pins.....
Old Sep 16, 2009 | 06:26 PM
EJ1_Sleeper's Avatar
The bitch pin is there for a reason, i would never replace it with a bolt...
the proper tool is all you need, i remove them in seconds now.
a trick with the SOHC, find a long *** 1/4 extension and hit it from the top down, works like a charm.
Old Sep 16, 2009 | 06:32 PM
beansandrice's Avatar
LOL
Only do this method if you want like 3 inches of slopp. It makes it feel like every gear is in neutral. I just fixed my friends thing with a spring pin.
Old Sep 16, 2009 | 07:01 PM
highroller54's Avatar
I hope your friend "thing" is feeling better.
Old Sep 16, 2009 | 07:04 PM
johnnyonth3spot's Avatar
The spring pin is there for a reason, mostly to keep the play out of your shift linkage.
Old Sep 17, 2009 | 02:25 PM
It sure is! LOL
Old Sep 17, 2009 | 02:43 PM
radex7's Avatar
I would recommend the 1/4 extension too. Piece of cake. I actually used 1/4 to 3/8 adapter and used all of my ratchet extensions to easily and comfortably push the pin out from the top.
Old Sep 17, 2009 | 02:46 PM
sh!ft's Avatar
Who the fack changed my title?!
this always works for me: a- c clip vice, an allen extension bolt and a 10 or 12 mm socket
Sirfallsalot243
Aug 14, 2007 05:30 PM
ej1 pilot
Apr 9, 2006 02:50 PM
98DC2teg
Mar 31, 2005 10:25 AM
NatedoggAZ
Apr 2, 2004 10:14 AM
GOTNOS
Feb 18, 2004 11:21 AM
