Suspension & Brakes Theory, alignment, spring rates....
***PLEASE HELP NOOB QUESTION. PUTTIN 5 LUG ON EK AND EG QUESTION.*****
Old Sep 16, 2009 | 12:38 PM
block131's Avatar
Default ***PLEASE HELP NOOB QUESTION. PUTTIN 5 LUG ON EK AND EG QUESTION.*****
HEY WUSSU H-T I HAVE A REAL QUICK QUESTION IM PUTTIN TYPE R SUSPENSION ON MY EG BUBBLE AND MY EK COUPE. I HAVE A SIMPLE QUESTION, WHEN I GET MY COILOVER SET DO I BUY THEM FOR A ITR? EVEN DOE THEY GOING IN A BUBBLE AND EK COUPE? OR DO I BUY EM FOR THE EG BUBBLE AND EK COUPE. SORRY FOR THE NOOB QUESTION. THANKS IN ADVANCE.
Old Sep 16, 2009 | 01:29 PM
block131's Avatar
Default Re: ***PLEASE HELP NOOB QUESTION. PUTTIN 5 LUG ON EK AND EG QUESTION.*****
cmon 6 views n no reply.. anybody..
Old Sep 16, 2009 | 01:32 PM
Rotten Egg's Avatar
the coilovers dont bolt to ur hubs...
Old Sep 16, 2009 | 01:37 PM
block131's Avatar
WHAT ARE YOU TALKING ABOUT YOU MAKE NO SENSE, SOMEONE ELSE PLEASE.
Old Sep 16, 2009 | 01:39 PM
block131's Avatar
IM ASKING WHEN THE 5 LUG CONVERSION IS ON MY EG BUBBLE AND MY EK COUPE. SO I BUY EVERYTHING FOR A ITR OR EVERYTHING FOR THE CAR ITSELF. FOR EXAMPLE WHEN I ORDER MY D2 COILOVERS SHOULD I BUY EM FOR A ITR OR FOR A EG BUBBLE AND WHEN I BUY EM FOR MY EK COUPE SHOULD I BUY EM FOR AN ITR OR FOR A EK COUPE. AND WHEN I BUY MY BRAKE LINES.. DO I BUY EM FOR AN ITR OR DO I BUY EM FOR A EG BUBBLE AND EK COUPE... THATS WHAT I MEAN...
Old Sep 16, 2009 | 05:43 PM
Rotten Egg's Avatar
like i said....ur coilovers dont bolt to ur hubs (what ur switching to ITR ****) unless u change control arms, its staying the same correct?
Old Sep 16, 2009 | 09:06 PM
punkdown's Avatar
I have a theory that if you turned off your caps lock and wrote your message like someone with half an education you would get more help with your questions. What trailing arm you are using has no impact on what shocks you can run. If you want to use standard **** keep your stock LCA's. If you want to use ITR **** use ITR LCA's. Its pretty easy dood. And what the hell is an EG BUBBLE?
^u mean lower control arms....ur coilover doesnt bolt to ur trailing arm...
Thanks, was thinking LCA but typed trailing arm.
Old Sep 16, 2009 | 09:55 PM
Rotten Egg's Avatar
on a side note tho....if i were u i'd upgrade to some function7 lca's (itr spec) on the eg and run jdm itr spec coilovers and rock out with ur **** out on them b!tchesi
my eg6 set up
Old Sep 17, 2009 | 10:43 AM
block131's Avatar
umm okay what does me writing it caps lock or lower case... have to do with how well educated i am 'dood' maybe i forgot caps lock on, ''dood'' thanks for ur help but keep your smart remarks to urself 'dood'. and second of all im not using the itr shocks n springs i just got the brake n hub setup. And a eg bubble is a eg hatchback, in NYC we call them bubbles cause the way their shaped.
Old Sep 17, 2009 | 10:49 AM
block131's Avatar
my eg6 set up
wow your setup is beautiful, i liek how it looks. how much u paid for that sway bar and what brand is it.
Old Sep 17, 2009 | 10:52 AM
jdmeg_six's Avatar
idk if this helps but i sold my friend my ksport and he went 5lug and everything bolt right up!.
Old Sep 17, 2009 | 11:26 AM
Rotten Egg's Avatar
in cali we call them eggs lol....the sway bar is custom powder coated...its an asr subframe and sway bar pack i bought....and function 7 coilovers...
long story short dude, ur stock stuff will work unless u switch the mounting points where the coilover bolts to over to itr stuff
Old Sep 17, 2009 | 04:58 PM
Function7's Avatar
What's up with the ALL CAPS..... you gotta learn to chill out/relax a little
All you need for the 5-lug conversion is the rear trailing arm and not the lower control arms. You do not need to get "ITR" coilovers, especially so on the EK since the ITR shocks don't fit an EK without custom arms.
BTW, here's a sneak peek for those with EG/DC's out there:
...they will be available very soon!
-A
Old Sep 18, 2009 | 08:31 AM
block131's Avatar
ooh okay thanks for the info, yeah i want the asr brace too, what kinda package was that? is that sway bar asr brand also?...and yeah i kinda figured all the stock stuff will fit, bu t i was gonna order coilovers n lca's online n didnt know what spec to buy em for eg's or itr spec but now i know thanks. and i think imma goo with the itr sec lca n coilovers looks sick bro lol EGGS lol eggs bubbles same **** lol thanks for the info doe ur egg is captiva blue?
Old Sep 18, 2009 | 08:35 AM
block131's Avatar
-A
damn is it really that serious if i write in caps lol liek cmon man. but anyway i'll write in lower case for now on...and wow that subframe bar is nice i could have swore i seen that out already but ti was for ek i believe
Old Feb 23, 2010 | 09:26 PM
xvphatsivx's Avatar
After reading this entire thread I guess I have a few questions.
1. Unless I'm missing something, why cant I just remove my old trailing arm and bolt up a complete ITR trailing arm.
2. With DA knuckles I need ITR hubs and what wheel bearing?
Old Feb 23, 2010 | 10:54 PM
nizzan4u2nv's Avatar
1. You can just bolt up itr trailing arms.
2. With da front knuckles the usdm itr or jdm ctr hub which is 32mm needs to be machined for da bearings.
http://www.ff-squad.com/technet/how-to/5lug.ef-da/
http://battlecat.8m.com/ITR%205%20lug%20on%20DA.htm
Old Feb 23, 2010 | 11:03 PM
xvphatsivx's Avatar
Thanks, thats the route that im going. You guys that are holding your hubs on with half engaged mazda nuts with eliminated washers are freaking CRAZY! It scares the **** out of me that there are cars on the road with stupid **** like this done to them.
Old Feb 23, 2010 | 11:17 PM
I wouldnt be so quick to judge. Noone has reported any problems "yet".
Bthasht
Mar 13, 2009 07:51 PM
eg64u
Paint and Body
Apr 23, 2007 10:47 AM
DesertCivic
Oct 27, 2004 08:20 AM
jimmhatch
Aug 31, 2004 03:19 AM
