what k24 would work?
Old Sep 16, 2009 | 04:27 AM
kobeballer96's Avatar
Default what k24 would work?
crv? accord?
tsx i kno does. im on my phone so not typing much
Old Sep 16, 2009 | 04:33 AM
nahonda04's Avatar
Surje.motorsports
Default Re: what k24 would work?
They will all work!
Old Sep 16, 2009 | 05:50 AM
Originally Posted by nahonda04
They will all work!
alright cool. so its not like tryin to swap a k20z3 in to a ep3 rght?
Old Sep 16, 2009 | 06:32 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
correct
Old Sep 18, 2009 | 11:26 AM
blkekcoupe's Avatar
if you use the accord block(k24a4) make sure you swap out the pistons if your doing a k20/k24 frank, the piston on the accord is different from the crv and tsx piston.
Old Sep 18, 2009 | 01:26 PM
josh's ep3's Avatar
Function > Form
You might get better results on your question in the K Motor section. Do some research there and I'm sure you will learn the best way to go about a build like this.
Old Sep 18, 2009 | 02:34 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
easiest way is full k24a2 swap from a TSX. Best k24 out there
Old Sep 18, 2009 | 07:47 PM
blkekcoupe's Avatar
what spaz said is the right correct way, if your on a budget then get the crv(k24a1) and slap your type-s head on it, you can get crv short blocks for less then 800 and then stick some tsx crank, piston and rods and your good to go with a frank if your on a budget...if you have the funds then complete k24a2 long block FTW
Old Sep 19, 2009 | 08:12 AM
will do sir and thanks Type-'S'paz and blkekcoupe. this my new project. after im done lowerin my car. so excited because this is gonna be my first swap. i watched friends do theirs on there ek's and eg's. now its my turn
Old Sep 21, 2009 | 10:15 PM
bambol's Avatar
hey orlando GL with the swap and please make a build thread! i'd be down to subscribe and follow along the way.
Old Sep 22, 2009 | 05:10 PM
i will be sure to that. as of now i got other things that i gotta handle so i can move on to the build!
Old Sep 26, 2009 | 11:39 AM
bluebird's Avatar
Do it
v4lu3s
Mar 28, 2012 06:20 PM
MIDNIGHTTUNER
Jun 5, 2008 08:32 PM
The_Head
May 22, 2008 06:14 PM
hondapwr
May 24, 2005 10:27 AM
Jerry31
Jun 29, 2004 07:47 PM
