B20 VTEC oil leak !!!! HELP
Old Sep 16, 2009 | 12:51 AM
itr1244's Avatar
Default B20 VTEC oil leak !!!! HELP
i'm using GE 84mm headgasket made for b20 vtec. . but the oil seems to be tranny oil because i didnt lose noticeable mount of engine oil. but the tranny oil did get lower.. so i replaced the driver axle seal myself.. and it had leak so i took it to honda dealer to get it replaced. they told me if it still leaks my half shaft could be bad.. so sure enough there was leak still. so i replaced my half shaft and my axles as well. and now it is STILL leaking. i'm about to go insane. any input would be helpful. thanks guys.
car doesn't smoke. and i closed off the oil gallery as well and got the head decked.
Old Sep 16, 2009 | 12:45 PM
itr1244's Avatar
Default Re: B20 VTEC oil leak !!!! HELP
and i found oil infront of the block too where it says HM
Old Sep 22, 2009 | 01:33 PM
itr1244's Avatar
took my oil sandwich adapter and took the o ring out and used gasket maker and i still see the oil leak. wtf
Old Sep 22, 2009 | 04:55 PM
itr1244's Avatar
it seems like the oil leak started at the front passenger side conrner of the headgasket, it's the corner where you can see the headgasket itself.
if it's head gasket i am thinking the problem would be worse. apparently i had oil leak from everywhere. i fixed my tranny oil leak. and the oil sandwich adaptor.. now i still have this leak. it's probably cam seal..
Old Sep 22, 2009 | 05:54 PM
PyroProblem's Avatar
Sounds like you have a mess of oil leaking from several different spots...
Id suggest cleaning everything really really well and rediagnose the true source of the leak...
Did you have the block and/or head decked? If so the dowel pins may be keeping the headgasket from sealing properly...Did you use the correct headgasket?
Old Sep 23, 2009 | 11:32 PM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
cam seal... and make sure all ur dizzy bolts are tight.. and ur valve cover gasket is new with silicone around the corners.. u must be new to hondas.. good luck
Old Sep 24, 2009 | 11:33 AM
whitaker_1991's Avatar
Did you use dowel pins when install you b20vtec? If you had the block decked or honed it is neceesarry to use a thicker head gasket because that has happen to me before. Judging from the location of the oil leak, it sounds like dowel pins to me as my friends b20vtec does that because he did not use dowel pins.
Old Sep 24, 2009 | 11:34 AM
Oh, if you did use dowel pins sometimes the dowel pins will not seat right and it will leak oil as well.
Old Sep 27, 2009 | 09:45 PM
itr1244's Avatar
no.. not really new to hondas.. had my itr since 2001 and this is my 2nd rebuild ...
just new to b20..vtec i didn't have oil leak issue on my last itr build. but this b20 is just oil leak everywhere.
i am using GE 84mm H/G..
head has been decked. and block was checked for straightness.
i'm pretty sure the dowel pins were in place.
just replaced the dizzy O ring and all new gaskets for the valve cover. and cam seal.
so i replaced the cam seal and noticed i didnt use liquid gasket around the corner (passenger side under cam plate) so i applied it and it seems like its leaking even more. going to have to try re doing the liquid gasket...
Old Sep 28, 2009 | 06:20 AM
gutted-dx's Avatar
Did you install the plug into the head properly?
Old Sep 28, 2009 | 10:31 AM
itr1244's Avatar
yes i had the machineshop guy to install that plug for me with Teflon tape.
and my compression ratio is 220 psi on all 4.
Old Oct 1, 2009 | 08:12 PM
gutted-dx's Avatar
Any progress?
Old Oct 1, 2009 | 11:49 PM
RED_90TEG's Avatar
there is something that u can put all around the oil that will dry it up... like compleatly dry then u can c where the new oil is comeing from.. there are a few sensors near the dizzy and cam seal area.. im not sure if there is oil running behind them check those maybe its loose and oils comeing out?
Old Jun 7, 2010 | 08:40 PM
itr1244's Avatar
i gave up on my car for a while.
i finally i took my car apart today. come to think of it now.. i think i know why my car was leaking!.
its the arp head stud. i blame myself for this cuz i was lacking knowledge about this.
i "hand tighten" it as it said on the instruction that came with arp bolt. and it said dont torque the stud down. so it got me confused.
you're supposed to tighten the stud all the way and back it up 1/4 turn so they are all even height.
when i hand tightened them they were NOT the same height.
so i am in a progress of fixing it. i'll let you guys know how it goes for sure.
Old Jun 11, 2010 | 04:36 PM
itr1244's Avatar
i changed the head gasket. I am pretty sure i fixed the problem
now one problem lead to more problems for me.
i had to take off the vtec oil line and now i have leak from the oil line to the head.
and more from oil adaptor sandwich
Old Jun 23, 2010 | 01:55 PM
itr1244's Avatar
Icon7 Re: B20 VTEC oil leak !!!! HELP
ok i FIXED the problem.
it was for sure the head stud being not installed correctly.
i just ran my car for the first time. i just put around 20 km. and no leak so far.
Old Jun 23, 2010 | 02:00 PM
nus_dogg's Avatar
Glad you got it fixed.
Old Jun 28, 2010 | 07:32 PM
itr1244's Avatar
ok
i lied.
my car is STILL bleeding.
someone just kill me
Old Jun 28, 2010 | 08:50 PM
Jimmy's Avatar
Global Moderator
ok
i lied.
**** man, that sucks.. Hope you get your issues worked out. I feel the same damn way.. My car has been a real headache these past few days
Old Jun 29, 2010 | 06:25 AM
slowcrx954's Avatar
I bet its your dizzy,take the cap off and I bet there will be oil.get a new dizzy.
Old Jun 29, 2010 | 11:10 AM
itr1244's Avatar
hrmm i'm pretty sure it's ok at the dizzy i have replaced the o ring on that too but i'll check again.
any input would be appreciated thanks guys
Old Jul 1, 2010 | 12:09 PM
itr1244's Avatar
your bet is wrong.
my dizzy is completely dry
here's my update
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/ls-vtec-oil-leak-2270330/
Old Jul 5, 2010 | 02:10 PM
FMN716's Avatar
have you tried changing your head gasket to the oemversion for your block, forgot to ask are you running a breather kit
Old Jul 5, 2010 | 05:46 PM
xzodiackillerx's Avatar
could be this! I have seen many people blow oil out of everywhere because of the no OEM breather on the B20vtec
Old Jul 5, 2010 | 10:03 PM
FMN716's Avatar
Yes my suggestion read over the Reliable guide to building a ls/vtec
you might get some other answers there but I think its also a good Idea to do the following
*Check that the block and head is not warped
*Use the GE dowel pins and get the OEM Gasket for your block which you will have to modify slightly, GE uses the vtec gaskets which are incorrect as you have the ls/crv block
*You need an oil catch tank/breather tank as the ls/crv head had its own kind of breather kit and the vtec head does not use this system in the head, your motor needs to breathe so give it lungs lol
