Super Stiff Clutch???
Old Sep 15, 2009 | 11:33 PM
felipe69's Avatar
Default Super Stiff Clutch???
hey i have an ef with a b20v! Ive put this swap in 3 different cars already! when i 1st got my swap i remember the clutch was real stiff! but i mean super hard! now its on my 3rd car and it is still super stiff that it breaks the cable clutch after a while! The only things ive changed is tranny, cable, pedals...... i have not changed the clutch or flywheel.....anyone have ideas wat causes the clutch to be sooooooo stiff???
Old Sep 16, 2009 | 12:23 AM
20-EM2-05's Avatar
Default Re: Super Stiff Clutch???
Uhh. Maybe because it's the Clutch .
Don't you realize that it's been stiff the whole time because you haven't changed the clutch?
Old Sep 16, 2009 | 04:58 AM
dephtone's Avatar
It's more than likely the pressure plate. Do you recall which Pressure plate you got?
My clutch is rated for 456 ft lbs and it's stiff as ****, the reason being is it has more clamping power. This is more than likely the reason yours is so stiff because of the power the clutch can hold.
Old Sep 16, 2009 | 05:32 AM
8VEYBEYB's Avatar
ever driven a porche? try those clutches , or a cobalt SS , or a camaro , or a roush mustang , I have driven all of those and every one of them the clutch is just super stiff , alot of people think its hard to drive them but really , it just takes time and practice.
Old Sep 16, 2009 | 05:50 AM
EJ1_Sleeper's Avatar
if your breaking cables you either need a new pressure plate, or you have to strong of a plate for a cable and need to look into a hydrolic clutch setup
Old Sep 16, 2009 | 10:30 AM
felipe69's Avatar
Icon3 Re: Super Stiff Clutch???
I do not know which pressure plate I have!! Could it be that the pressure plate needs to be resurfaced!? Which pressure plate would I need if I have a different one!?
Old Sep 16, 2009 | 10:34 AM
8VEYBEYB's Avatar
You need to open up the motor/tranny and look inside , should say HTC , ACT , Exedy , etc on it and most you can tell just by the color like yellow would be ACT , no way of really telling what kind though except the shape. I had to open up mine take it out , and look onlineto compare to figure out which one I had.
MichealSenior
Feb 17, 2009 12:56 AM
1990EFHATCH
42
Nov 21, 2008 09:30 PM
DB1_559
Jun 23, 2006 03:02 PM
quik89
Sep 15, 2004 06:21 PM
bloodyknuckles
Jun 4, 2004 07:26 PM
