What is the B16B's Rod length? (reliable sources only please)
Old Aug 27, 2002 | 05:21 PM
Michael Delaney's Avatar
Default What is the B16B's Rod length? (reliable sources only please)
nrg-racing.com has it listed at 144mm (making it a 1.86 rod ratio engine)
I've heard that the CTR rod ratio is actually 1.77 (a little better than the 1.74 of the B16A)...this would make it a 137 mm rod instead.
Which is it?
Old Aug 27, 2002 | 05:46 PM
HXMan's Avatar
Default Re: What is the B16B's Rod length? (Michael Delaney)
Most likely it is a 1.86. You probably can do the math. Basicly it is a block with b18c5 deck height, but a b16 crank. So....a ITR stroke is 87.5? b16 is 77mm...
So, we could in theroy say a b16b has a rod 10.5mm longer then a b16a...so...
b16a rod+10.5mm/77mm stroke...what is the lenght of a b16a rod?
144/77=1.87
[Modified by HXMan, 8:49 PM 8/27/2002]
Old Aug 27, 2002 | 06:11 PM
Default Re: What is the B16B's Rod length? (HXMan)
I have it on good authority that it is the ITR rod since the CTR is just a destroked B18C5 block.
137.9/77.4 = 1.78 r/s
where did you hear that it was a 1.86 r/s?
Old Aug 27, 2002 | 06:24 PM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
here is an unreliable answer- 508mm
later
matt
Old Aug 27, 2002 | 06:48 PM
Stryker908's Avatar
Default Re: What is the B16B's Rod length? (champITR)
they are about this long (moving hands apart )
Old Aug 27, 2002 | 06:52 PM
DragII's Avatar
25 Year Member
144mm
http://www.nrg-racing.com/tech_engine_specs.htm
Old Aug 28, 2002 | 12:24 PM
Default Re: What is the B16B's Rod length? (Antonio S)
dude if you read my post I already said where I got the 144mm number from. I already knew about nrg...I emailed them as to where they got that number from. As I said other sources say it is shorter.
Old Oct 24, 2002 | 07:13 PM
another classic example of how highly technically advanced we are here....
Old Oct 24, 2002 | 07:37 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
You came back two months later just to say that?
Old Oct 24, 2002 | 09:04 PM
Default Re: What is the B16B's Rod length? (vtecvoodoo)
sure. why not? I just wanted to see if anyone came up with the specs or not and I read the other replies I hadn't seen from the initial posting. the moving hands apart and 508 mm replies are classic. We are honda-TECH...right? sorry Ryan, it's not about you and you know it..it's about the way things have changed here in general....
[Modified by Michael Delaney, 1:05 AM 10/25/2002]
Old Oct 24, 2002 | 09:22 PM
R_yd's Avatar
so what's the true rod length?
Old Oct 24, 2002 | 09:41 PM
racecarpete's Avatar
try the tech forum or the forced induction forum. They know their stuff.
Old Oct 24, 2002 | 10:00 PM
genius's Avatar
Default Re: What is the B16B's Rod length? (SilverCivic2k)
itr rod.............................137.9
diff in stroke/2..................+5.1
ctr rod...........................=143
its in the neighborhood of 143 ,give or take a few thousands(ctr have higher comp. height then itr pistons by 15 thousands so rod might be slightly shorter then 143 but not much.
143/77=1.857
r/s ratio is 1.86
Old Feb 8, 2005 | 11:31 AM
UncleD's Avatar
Default Re: What is the B16B's Rod length? (genius)
Sorry to bump an old thread, but I REALLY need to know this.....I can't find anything at all on this!?
whyahonda
Jun 9, 2004 09:24 AM
boosted3g
Jan 9, 2003 02:28 PM
vwandhondaboy
Feb 6, 2002 07:55 PM
Michael Delaney
14
Jan 2, 2002 07:57 PM
H22CIVIC
Oct 1, 2001 03:30 PM
