"ls" vtec head bolts
You're not supposed to reuse factory style head bolts even if they are 1 day old. They stretch when you torque them, so when you try to use them again the torque and strength properties aren't the same. Head studs, like ARPs, are reusable.
you don't know sh*t.
do some research before telling people wrong answers.
b18a/b, b18c1, b16b and b18c5 decks are a bit longer so they require longer head bolts
with all the research that i have done i have not seen any head bolts that have any longer ones in it... an my block is a 96 ls with a built bottom end to handle higher rpm and my b16 head is off a 00 civic si just for some helpful info.... so what im gettingfrom anwsers is i need b18 head bolts or arp studs
