Stereo wiring issue
Old Sep 15, 2009 | 06:10 PM
LittlesilverEF's Avatar
Default Stereo wiring issue
Hellooo.
This may sound like a noob question/problem but I'm getting frustrated and tired of it not working.
So basically I bought my 90 si that had an aftermarket cd player. I decided I wanted to switch it back to a stock Honda deck so I could use the tape player and it would look nice and oem.
However when I started doing the wiring (which should be very simple), I came across an issue where it would seem to not get power. I used a reverse harness that I bought from Best Buy. I hooked up all the wires correctly as far as I could tell by using the following diagram:
http://www.installdr.com/Harnesses/HA-Wiring.pdf
In the diagram it says to hook up the yellow/red wire from the dash to the red wire from the stereo harness for the ignition. However I do not see a yellow/red wire coming from my dash. So I tried the red/yellow which does not work. Also I know something is hooked up right because the red led anti-theft light will blink every now and then when I have my car turned off.
I'm very confused and frustrated because I've done this before on other cars and I had no problem.
Any help would be much appreciated.
Old Sep 15, 2009 | 08:52 PM
macknjack's Avatar
Default Re: Stereo wiring issue
ya i would really like to know the answer to this question as well. I believe we are looking for the accessory wire. I tried to do the same thing to hook up my stereo correctly and didn't succeed.
Old Sep 15, 2009 | 09:06 PM
For real, any help please?
I know the wiring worked before because the aftermarket stereo worked fine.
BUMP!
Old Sep 15, 2009 | 09:36 PM
Ldo's Avatar
Ldo
Get a $5 test-light and find the 12V switched wire. Turn the key to On then use the test light to find the wire. Different year/model might use different wire colors. Do you see the White/Blue wire from your harness? that's the constant 12V, which is always hot. You probably have that constant 12V hooked up correctly because your antitheft light is blinking.
I remember on my CRX, the red/yellow and yellow/red are almost identical to each other.
Again, the cheapo test-light will do you wonder in this case, if you haven't tried it already.
Old Sep 16, 2009 | 06:33 AM
jlicrx's Avatar
white/blue is constant power - comes from underdash fuse box (fuse #12) and runs to cigarette lighter relay and branches off to the stereo for constant power
yellow/red is switched power - comes from underdash fuse box (fuse #17) and also runs to cigarette lighter relay
from cigarette lighter relay, 2 wires come out, one black for ground and one white/green which runs to the lighter and branches off to the stereo for switched power
Old Sep 17, 2009 | 10:10 PM
Thanks guys, I've been busy the past couple days but I will try to do it tomorrow and let y'all know!
Old Jan 23, 2010 | 07:52 AM
macknjack's Avatar
so i forgot i posted in this thread. i read reply #5. i didnt realize that the power for the stereo would come from the cigarette lighter. there was no fuse in there. works like it should now. thanks man!
y2kferari
Audio / Security / Video
Feb 15, 2010 02:35 PM
unix4linux
May 12, 2008 06:07 AM
drift9
14
Feb 10, 2005 09:20 PM
samv2595
Jan 27, 2002 01:51 PM
