H22T KNOCKING from head
Old Sep 15, 2009 | 05:08 PM
juan400hp's Avatar
Default H22T KNOCKING from head
97 Prelude with Mahle 9-1 Pistons with Eagle Rods, ARP Head/Main Studs, RC 550's, Cometic HG and a P28 ECU w/ Crome and a greddy Turbo Kit. The engine has a loud ticking noise at low RPM's that seems to subside with RPM's It's possible that the engine noise overpowers the noise and it still exists but it's less audible with RPm's..under valve cover everything looks fine and a valve adjustment was just done since I thought it was the valves so I had machine shop inspect the head and replace all valves... The sound almost sounds like a rod knock but it definitely sounds like it's coming from the head. the ticking/knocking noise seems to come from lower on the head...and It's not just an injector ticking; it's pretty loud and more like a knock. PLEASE HELP!
Old Sep 16, 2009 | 01:36 PM
juan400hp's Avatar
Default Re: H22T KNOCKING from head
Bump for any help
Old Sep 16, 2009 | 01:51 PM
bar'dh22's Avatar
check the lma's
Old Sep 16, 2009 | 02:00 PM
kevinlude's Avatar
Hi, my Prelude has the same problem but it's all stock except the AEM CAI.
So if it's the LMA, how do I fix it? Thank you
Old Sep 16, 2009 | 04:12 PM
bar'dh22's Avatar
replace them
Old Sep 16, 2009 | 05:21 PM
juan400hp's Avatar
Originally Posted by bar'dh22
check the lma's
Lmas are the 2 long cam covers right? How can that go bad..it just sits there and is tighten down by bolts...
Old Sep 16, 2009 | 06:26 PM
bar'dh22's Avatar
wow you dont know **** about your own motor, no lma= lost motion assemblies do some research before you make incompetent posts
Old Sep 16, 2009 | 06:32 PM
katzenjammer84's Avatar
Easy does it noob. Everybody has to learn.
Old Sep 16, 2009 | 07:11 PM
Enzo15's Avatar
What are the LMA's? Dont think we have them on our Scion motors, so Im not sure what they are XD.
bar'dh22's Avatar
just because you think you know how to read my join date dosent mean this is my first hondatech name dumb ***
Old Sep 16, 2009 | 07:21 PM
ProjectBB6's Avatar
easy guys
Old Sep 17, 2009 | 03:11 AM
Glad I asked. Good luck with the pompous attitude.
Old Sep 17, 2009 | 03:17 AM
Paul-R's Avatar
your a dumb a** .
Any type of knock that seems to be getting worst isn't good at all . I think it's time to take the motor out and take it apart to really see whats the problem not worth playing the guessing game on a forum when it comes to engine knocks .
Good luck man ,
Old Sep 17, 2009 | 05:35 PM
BB1 H22A LUDE's Avatar
Getting back onto topic, there are a few write ups on LMA replacement already, not any that I know of for the H22A but its the same procedure. Takes a fair bit of time I would imagine but may be well worth if the nasty but shuttle LMA sound is present.
https://honda-tech.com/forums/showth...MA+replacement
Old Sep 17, 2009 | 09:37 PM
juan400hp's Avatar
Thank you
Old Sep 17, 2009 | 09:41 PM
juan400hp's Avatar
I'm always stuck at work and I don't have much web access! And that was a guess cause some1 else told me it was something like that.
Old Sep 18, 2009 | 02:29 AM
juan400hp's Avatar
Is there such thing as lifters going bad on the h22 head?
Old Sep 18, 2009 | 02:58 AM
dagle's Avatar
what tune is it on? and who tuned it? surprised no one asked that
Old Sep 18, 2009 | 06:28 AM
road.head's Avatar
is the sound one speed or double speed?
Old Sep 18, 2009 | 09:30 AM
Apex1972's Avatar
Are you running the Mahle Gold series or is your block sleeved?
Old Sep 20, 2009 | 07:12 AM
juan400hp's Avatar
Yes tthe mahle gold series
Old Sep 20, 2009 | 07:16 AM
juan400hp's Avatar
  1. Originally Posted by dagle
It doestnt have a proper tune..is tuned on a v-afc by pruven performance
Old Sep 20, 2009 | 08:01 AM
Apex1972's Avatar
So how many times have you been banned?
Old Sep 20, 2009 | 08:06 AM
Apex1972's Avatar
please do not drive your car like that. it sounds like you already got some issues under the valve cover so don't blow it up.not sayin I know for a fact its gonna do that but its not worth the risk IMO you already have a nice looking parts list so spend a grand or so more and get a S300 and a proper tune, and see what the ticking sound is. My bet is on the LMAs. these turbo Preludes are very tricky it seems but if you get the bugs worked out,should be worth every bit of headache.Good luck man.
Old Sep 20, 2009 | 07:47 PM
juan400hp's Avatar
Thanks bro.I can't wait to see the power with a proper tune..I already ended. Up with 330whp at 12psi on a 20g turbo.(small) and afc....so I hope a lot more with good tuning..BACK TO SUBJECT...UPDATE!! I DROVE IT TO MACHINE SHOP AND HE TOLD ME TO BRING HIMTHE OIL FILTER TO LOOK FOR SIGNS OF DAMAGE TO BEARINGS, AND HE ALSO AGREED WITH U ON REPLACING THE LMA'S....but my only question is, don't the lmas only make a difference on higher rpms? Because u can only hear the knockin at low idle when parked, and as soon as I start to drive and I'm not on high rpms...when I'm parked and I rev it up to about 3000rpms, u can't really hear the noise....
